Instructables has quite a few guides on how to make Solar USB Chargers, including the very well done guide on how to combine a Lady Ada Minty Boost circuit with a solar + lithium ion battery. Great, but a bit expensive to make and not a very simple project for the weekend DIY person.
Well luckily for us I know how to make one for under $20 that is better in nearly every way and also completely fits into an Altoids Tin. Covert style.
(If you want a more powerful USB Charger, a Heavy Duty one, I have an instructable for that as well.)
Remove these ads by
Signing UpStep 1What You Need
USB Charging Circuit
Solar Panel 4V or greater
AA Battery Holder
AA Rechargeable Batteries
1N914 Diode
Altoid Tin (or whatever)
Wire
Tools:
Soldering Iron
Solder
Tin Snips
Melt Glue Gun and Glue
Tape
Cost is less than $30. I can make one for under $10 when I buy parts in bulk. I have a kit available at my website BrownDogGadgets.com which has everything you need to make this project. Also, if you're lazy, I do sell made versions in a variety of tin styles.
-Doctordv
Fact: It will take you more than 10 years to pay back
Solution: Using Surplus Solar Cells You can get pay back in 1-2 years
There is an Engineer from Chicago his name is John Sommer
He explain it All in his diy solar panels Blog Search for him using Google
Type "top diy solar panels" Open the first Result.
Note: Ignore the adds at the top.
I am looking to build a slightly different version of this instructable, but with supercapacitors instead, to make this "super-green". Do you know if it would be possible to just use supercapacitors to completely replace the batteries? Even if it would only work while in the sun, that would be fine with me... Any help would be great!
The biggest environmental impact will be the energy used to make the refined silicon for the solar cell, most likely from coal burnt in China. Switching to super caps would not resolve that.
The only downside is that super caps cost a lot of money compared to just using some AAs. Plus because of how little power this thing uses a set of AA batteries would last a very very long time.
http://www.ladyada.net/make/mintyboost/changelog.html
Apple has apparently changed and rechanged their load protocal to make it difficult to charge. Adafruit has tried to keep up with it.
You also don't need to worry about overcharging. We're not throwing enough current at the NiMh AA batteries to overcharge them.
If it makes a difference, I'm using the same USB from the same emergency charger as you did.
Thanks in advanced.
I dont know if this curcuit would handle the 5watt DC power source (beyond my EE knowledge)
Also, I know heat will damage the batteries for sure, however, again I'm not sure how hot exactly they can get before it damages them.
My situation is that I live in Phoenix Arizona and I really want to make one of these, however, I don't know how long I will be able to leave the charger in the sun without it getting damaged due to excessive heat. It's really the solar cell that I am concerned about as I am sure I could find a way to keep the batteries fairly cool in the shade while the solar cell is in the sun.
Do you have any suggestions?
But yes, the batteries may be a different issue all together. Keeping them cool might not be a bad idea.
Try this out. External solar cell, long wire, jack and plug setup.
http://www.browndoggadgets.com/store/solar-kits/heavy-duty-usb-charger-kit/
Help? :/
Does it create enough power to do this?
I would like to use the 4v solar panel or do I need a larger panel?
The solar cell isn't powerful enough to power an iPod all by itself.
A larger cell, one outputting over 200mA, will probably be enough.
I just posted a new Instructable on how to make a Solar Charger using a big solar cell along with a Jack and Plug setup. Might be up your alley.
(Though I'm guessing you're going to be ok.)
Two solar positives together, then the diode off of them.
Well I recently tried with a new batch of these circuits and my iPhone 4 charged perfectly. Big surprise to me.
If you're going to be using this with only an iPad or iPhone you might want to use a different circuit. I have one that has a retractable iPhone/ iPod/ iPad cable on it, as opposed to a USB port. Handy.
