Solar Arc Reactor
9,249
180
Posted
Introduction: Solar Arc Reactor
The idea of Iron Man's infinite power Arc Reactor is awe-inspiring and led me to create the next best thing..a solar Arc Reactor night light!
Step 1: How It Works
The solar cell charges a lithium ion battery during the day and at night the LED Arc Reactor style ring switches on.
The circuit uses a LDR especially tweaked using a 270k resistor to turn on the night light when it starts becoming dusk.
The transistor in the circuit simply activates as the on switch when the light levels change.
Step 2: The Parts List
Soldering iron
Solder
Flux
Tweezers
x10 white smt LEDs (XPCWHT-L1-0000-00C01)
Tin copper wire, any strong flexible gage.
Insulated wire
Blank pcb breadboard.
3904 transistor
LDR
270k resistor
Schottky diode
3.6v Lithium ion battery
5.4v + solar cell
Glass jar
Step 3: The Circuit
Follow my circuit drawing and picture of the PCB.
The schottky diode is on the back of my solar cell between the positive of the solar cell and battery positive.
Depending on what value LDR you have, you might have to change your normal resistor value accordingly.
Use a variable resistor first to get the LEDs to switch on at the right light levels.
Create a ring of tin copper wire and a slighlty smaller one to fit inside and solder ends together.
Solder the negatives of all LEDs to one ring and positives to the other ring.
It can be tricky and the rings get very HOT!
Step 4: Future Reactors..
I've since created an arc reactor bag, with a wafer thin flexible solar cell and a smaller battery.
Also I've made a replica arc reactor from the Iron Man 1 movie, check out my other Instructable!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
3 Comments
