Solar Assisted Composting Toilet
 by lamar5292
The following is an excerpt from my book Simple Solar Homesteading (www.simplesolarhomesteading.com)
Composting toilets have been used for many years and commercial composting toilets are available and used by many off grid homes.
Human waste can be safely composted into valuable fertilizer that can be used around fruit trees and shrubs but not recommended for gardens.
Sources:
http://www.jenkinspublishing.com/humanure.html
http://en.wikipedia.org/wiki/Humanure
The problem with commercial composting toilets is they require a tank inside or under a house, must have urine and feces separated, and do not keep microbes warm enough to be efficient.
Human waste is already partially composted by the bacteria present in human bodies and when placed in a composting toilet the waste is quickly consumed by microbes and turned into compost that is full of nitrogen and minerals that is valuable fertilizer.
I live off grid in a solar and wind powered cabin and I wanted a composting toilet that would be more efficient than commercial models and could be adapted to any home for use to replace conventional sewer lines or septic tank drain fields.
I designed and built a small test model that uses solar to heat the composter and remove excess moisture through evaporation. I have used my solar assisted composting toilet for 5 years and it has worked wonderfully!
Microbes thrive in warm temperatures between 50 degrees and 98 degrees. Below 50 degrees microbes hibernate or die and the compost process slows down.
By heating the composter with solar the microbes are kept warmer and work faster and the excess moisture form urine is quickly evaporated away leaving only a small amount of solids that will be composted into a fine fluffy clean smelling fertilizer.
The Solar Assisted Composter is comprised of four parts:
1) The toilet which can be a porta-potty or 5 gallon sawdust toilet
2) The tank which can be made from cement block or a poly tank
3) The solar cover which can be made from plywood and single pane safety glass or used windows
4) The exhaust vent for moisture evaporation which is a length of black pvc vent pipe 3" dia.
HOW IT WORKS:
There is no need to separate urine and feces in this composting toilet and you can use either a commercial porta-potty toilet or 5 gallon bucket sawdust toilet (see http://www.appropedia.org/Waterless_Toilet)
The human waste is collected in the toilet and emptied into the top of the solar assisted composting tank that sits outside facing the sun.
The sun will penetrate through the glass and heat the chamber keeping the microbes at a warmer temperature where they will quickly go to work composting the waste.
The heat will also evaporate off excess moisture from the waste that will escape out the exhaust vent pipe.
You can keep adding human waste as it is created until the tank is approximately half full at which time you should empty the composted material from the bottom of the tank using the compost door and this can be applied to your fruit trees and shrubs.
PLEASE NOTE:
This solar assisted composting toilet is not designed to handle the water waste from other sources like sinks, showers, tubs, or washing machines. It is only for human waste composting.
Water from other sources is gray water and can be filtered and used on gardens, lawns, trees etc.
I have supplied basic drawings and dimensions and this can be adapted to your own needs
NOTE: If you would like to learn more about off grid homesteading, solar and wind power please visit my website www.simplesolarhomesteading.com
Step 1: The Toilet
The toilet used with the solar assisted composter can be either a commercial porta-potty or a 5 gallon bucket style toilet.
Sawdust bucket toilets are used by many off grid homes and as waste is added a scoop of sawdust or peat moss is also added to absorb moisture, reduce smell and assist microbes.
Toilet paper can be added to composting toilets but you should avoid heavily perfumed toilet papers.
Never add chemicals or cleaners to a composting toilet as these will kill the natural microbes that are necessary for decomposition.
Many people design very nice sawdust toilets for their homes and to see examples go here:
http://humanurehandbook.com/album_toilets/album_toilets.html
http://weblife.org/humanure/chapter8_2.html
http://www.appropedia.org/How_to_make_and_use_a_sawdust_toilet_%28original%29
Dr.Bill says: Feb 16, 2013. 11:03 PM
The Chinese use big concrete tanks to compost to nite soil. The vent tube they use at the top, they use to collect gas that they use to cook with. The gas is removed via compressor to storage tanks. When the compost tank stops producing the heavy concrete lid with the vent pipe is removed and the nite soil is taken to the rice paddys for fertilizer. The tanks serve whole communities.
dianakbrown says: Aug 23, 2012. 1:16 PM
Thanks! Just preparing to go off-grid in a week. So this is just what I was looking for!!
rnekrasov says: Apr 11, 2012. 10:48 PM
спасибо за отличные советы http://idunasvadbu.ru
Blofish says: Feb 6, 2010. 1:42 AM
Thank you for posting this. I was just wondering is there a risk of the compost getting too hot and kill all the microbes?
ecowaters says: Mar 6, 2011. 1:27 PM
This is a poop composter, but not a composting toilet.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
