3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar Backup for HP mini
This is a solar charged battery backup for My HP mini 1032NR. The solar panel is quite small so charging is less than fast, I have not tested it yet but I assume it will take in the neighborhood of a week or so. It's all OK, the entire thing cost less than $50. For a comparable manufactured product you will be spending well over $300.00 according to my research. A quick note on the Life PO4 batteries "wally world" has them in a pack of 4 for $10.00 you will need 2 packs. They can be quite fickle so be careful with your connections. Nobody wants these things to start a fire. If you like this instructable let me know via comment I wiil post some more of my gadgets. For gods sake use a miltimeter and know the voltage of your pc. This project can be applied to any laptop not to mention a large assortment of portable devices IF YOU KNOW THY VOLTAGE!
Step 1Get your stuff together
You will need:
1 set solar Christmas lights (a solar garden light will work too)
Wire
Shrink Tube
Battery Holder(s) equal to 6 AA size
Project Box
Switch
Multi Meter
Male adapter (Size of laptop power input)
Male adapter (your choice)
Female adapter (matching your choice male)
Hot Glue!!!
13 comments
Mar 5, 2010. 5:46 PMDsk001 says:
I would like to know how long, or how much charge that can give the netbook.
Jan 12, 2012. 5:33 PMdrbill says:
I have that same Christmas light assembly. I took the LED's off and separated them. I measured the output from that same as yours solar cell and I find it puts out only 6.8 volts. The cell is charging a 3V 230mAh AA battery. Only 1 battery at 3V.
I don't see how you can plug it into the 19+volt power plug on your laptop and get it to work.
Mus Be Magic~
Mar 7, 2010. 12:42 PMironsmiter says:
as built, it's 6x600mAh @3.6volt
my acer aspireOne takes 19Volt input @2A.
That would give between 10 min, and 1/2 hour.
Better(aka bigger capacity) batteries, MORE batteries, lower power netbook, etc...will all increase the useful run-time you can get.
Not so much useful as-is, but a pretty good proof of concept.
At least for laptops. This would work really well for a cellphone, mp3 player, pda, or such. Even a portable dvd player(my portable takes a miserly 9Volt, at less than 1A).
Feb 22, 2011. 3:19 AMagent harmsy says:
Having got my first laptop (a hp pavilion dv6), and just starting uni, I've been looking at cheap extra power solutions for my laptop. I did physics in yr 12, but this has me stumped... "as built, it's 6x600mAh @3.6volt" - how do you draw 19V from that? Or is each battery 600mAh and it's overvolting the laptop slightly?
Oct 31, 2011. 2:31 PMpolice098 says:
tray a lower mAh batterys
Nov 2, 2011. 10:37 AMironsmiter says:
lower mAh won't do squat for the voltage issue.
All THAT will do is reduce your available power.
you COULD change the battery chemistry.
but then you'd need to change the charging circuit also.
16 AA NiMH cells would get you RIGHT AT 19.2 volt when fully charged(close enough for ANY general power circuit).
You would need a new charging circuit between the batteries and solar cells, and you're going to be charging for DAYS, if not longer. The up side would be a much improved run time(2600mAh@19.2V vs 600mAh@21.6V using the cells I have in my spares box) and slightly increased safety(LiFePO4 cells are pretty darn safe, as far as li-ion goes). Downsides include the afore mentioned long charge times, vastly increased size and weight,
Nov 13, 2011. 3:53 PMpolice098 says:
your to write when i think about it nice work
Feb 23, 2011. 2:33 PMironsmiter says:
You nailed it.
It is 6 batteries in series, for an AVERAGE of 21Volt(25v high to 18v low).
The internal charging circuitry of your laptop is designed to handle a healthy range of voltages. Some makes and models more than others.
For instance, I have an old IBM pent2 laptop that can easily handle from 15V through 24V input. My fathers modern IBM can only handle 18V to 20V.
Nov 13, 2011. 3:59 PMpolice098 says:
hers some thing for you to think about i had a laptop start up with just using i think 5v from a usb wire from a different laptop and you can use that power and with some twiks you can charge your own laptop but i had to be carful i dident short out the out let for the usb cable
Nov 2, 2011. 1:45 AMpolice098 says:
i canot say too much about this yet but i have made a devise for a laptop that runs by its own power without having to plug it in its the one am using now i have had it running fore two days now and the battery is still at 96% all i need to do is get the wiring and bored manufacturd into a small box which will be a fan cooler too and the idear was from a woman and is in the middle of being Patent –legal
Mar 14, 2010. 5:29 PMpirateaboard says:
Your diagram isn't clear as to how the switch works (3 prong so SPDT?), but ground should not go to the switch in any way.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:cocodlicious
After being born as a poor black child I set my sights on world domination. With the Mighty Mo Mo by my side we seek out the strange and bizzare to add to the ever growing collection of our minions. M...
more »
