Solar Bike Stereo
Solar Bike Stereo
 In this instructable I will show you how to make a solar powered bike stereo box that fits in a milk crate, which you may already have on your bike!  This instructable assumes you have some proficiency in woodworking and soldering, and is really about the solar to battery circuitry and the options it provides.  This system could be used for any variety of applications that run off 12v DC.
In designing this project the box went through many phases, first it was battery powered, then the solar was added, and more extra bits kept finding their way into the box.  Because of this the photos will appear somewhat inconsistent, so I have provided some easy to read drawings for clarification.
Step 1Materials
Materials
  Parts you will need:
wire
car speakers
solar panel (Sunforce 5watt trickle charge)
milk crate
mdf
tompsons water seal
polyfil
milk crate
DPDT switch
M-F Audio Cable
Power jack and plug (to match whatever your amp comes with!)
8 threded inserts
assorted screws
  Tools you will need:
Soldering Iron
Table saw
Clamps
Screw driver
Drill
17 comments
Jun 17, 2011. 10:59 PMLemurX says:
Fantastic project with totally awesome results! I was wondering though, would it be possible to use a smaller solar panel? I realize the charge time would be increased, but the application I have in mind would be best with a smaller panel. (also a little cheaper) Sunforce seems to make durable panels, so this was the panel I had in mind - http://www.amazon.com/Sunforce-50013-Motorcycle-Powersports-Battery/dp/B001D6GYLO/ref=sr_1_3?s=hi&ie=UTF8&qid=1308374827&sr=1-3
Jan 24, 2011. 2:08 PMAMP678 says:
This is really cool. How much did it cost?
Jul 21, 2010. 9:59 AMbjrcboy says:
How long would it take the battery to charge from being completely dead? How long does the music last once it's at full charge? Thanks!
Jun 4, 2010. 11:52 PMciaran.mooney says:
All I can say is, Flogging Molly rock and should rightly be played from a moving speaker in public places!
May 12, 2010. 8:08 PMeastonj says:
 I had a thought about making the boom box so its always charging a battery when its playing music in the sunlight. i came up with using two batterys and no ac/dc plug bc i havent figured out how to wire it. i'm having a hard time wrapping my head around how you soldered all the ground wires together and just put the positives in the switch. i plan on using a knife switch for aesthetics, and thats got me all confused. could you help me out? i drew up this diagram of how i am thinking it should go.
thank you in advance!
May 12, 2010. 10:34 AMeastonj says:
And also, why do you not want to solar panel to charge the battery when the battery is in use? would that not be beneficial? or the point for that matter? from what i am reading it seems like in order to use this, the amp is not powered when the solar panel is charging?
May 12, 2010. 1:31 PMeastonj says:
i asked my coworker about why you wouldnt want to charge the battery while its in use, and he mentioned that the battery's memory could get messed up by it discharging yet remaining at the same capacity. makes reasonable sense.
you've inspired me to create my own. i do not have a bike yet, but i frequent the beach and the wilderness so this is F***ing fantastic! thank you and keep up the good work!
May 12, 2010. 10:04 AMeastonj says:
with your DPDT switch, can the AC/DC also charge the battery?
May 7, 2010. 2:49 PMcrazybuthappy says:
Nicely done! I really like the fact you now have a self contained "sound cube" that could be taken anywhere there is sunlight. Just ploop it down, add an MP3 player, instant party.
May 4, 2010. 10:25 PMacaz93 says:
Wow! I must say this looks really professional! almost like store bought!
Well done!
One more thing, what's the name of the song on the video ?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:mbmosher(Check it!)
