In this instructable I will show you how to make a solar powered bike stereo box that fits in a milk crate, which you may already have on your bike! This instructable assumes you have some proficiency in woodworking and soldering, and is really about the solar to battery circuitry and the options it provides. This system could be used for any variety of applications that run off 12v DC.
In designing this project the box went through many phases, first it was battery powered, then the solar was added, and more extra bits kept finding their way into the box. Because of this the photos will appear somewhat inconsistent, so I have provided some easy to read drawings for clarification.
you've inspired me to create my own. i do not have a bike yet, but i frequent the beach and the wilderness so this is F***ing fantastic! thank you and keep up the good work!
If your amp is drawing 2 amps and you have it hooked up to the battery (not charging), then the battery will supply the full 2 amps---simple.
If you are charging your battery at the same time that your amp load is on, then your panel will supply .375 amps (optimally) and your battery will supply the remaining 1.625 amps.
Now for the BUT --- If your amp is on for too long and your battery can't supply the necessary current, then the amp might start trying to suck more power from the solar panel than it can provide---potentially causing overheating and damage to the panel(?).
PV arrays on houses are hooked up to batteries that are constantly being used, so I don't see there being any problem with charging a battery while there is a load attached. House arrays have better backup systems like a charge controller or a generator that can kick in if the batteries are getting too low. Since we probably don't want a generator in our milk crate we'll just have to mind our battery a little more closely.
Also, am I correct in interpreting that there is nothing attached to the negative terminal on your battery?
Thanks!
$60 - solar panel
$50 - Amp
$20 - Battery
$70 - Speakers (Car audio I recycled from another project)
$20 - Other stuff (wire, switches, MDF, etc)
$220 - Total
But you could probably save a bunch using different speakers
thank you in advance!
Well done!
One more thing, what's the name of the song on the video ?
The song is Reiga's Bad Habit by Professor Kliq on the Community Service II album.
