3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar Boat Kit :: KidWind Project
Step 3Building the hull
Building the hull
There are many ways to design the hull for your solar boat. To begin, use the pink foam or material you found for the hull. You should use a material that will float well. Use a marker to draw a boat design. Any design will work, but for an optimal boat design, see the tips about drag discussed later. Make sure it is large enough to float the motor and solar panel! Be creative! **ADULT HELP NEEDED!!** Using a hobby knife or serrated blade, cut out your boat shape.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:kidwindrob
