3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar Buzzer Prank
Solar Buzzer Prank
In this instructable I will describe to  you how I made a solar powered prank for April fools day.
The goal of the device was to be at least 50% recycled materials and to cost no more then $5 per unit to make. As a side effect these devices can be mass produced for a larger distribution of the prank or to intensify it in one area.
The simplest idea that I came up with to meet these goals was to use a trashed solar garden light attached to a 3v piezo buzzer. When in the sun the device will produce a rather annoying buzz.
The solar cell from the garden light was removed and the housing and circuitry was retained for future use.
Before buying any additional part I did some research on how much power I  had to work with.
Using my multimeter in voltage mode I recorded an open circuit voltage of 2.8v in moderate light and 3.5v in full light.
Then I switched the multimeter over to current mode and measured the short circuit current to be 50ma in moderate sun and 75ma in bright sun.
Step 1Purchasing parts
Purchasing parts
Knowing that my solar cell will output 3.5V at 75mA in bright light and 2.8v at 50mA, I purchased a radioshack part #273-0053 3V Mini Buzzer. ~$3.75
The specifications met the power supplied of the solar cell.
Voltage rating 1.5-3V
Current Consumption 15mA MAX at 3V
These numbers indicate that I could run 3 of the buzzers in parallel simultaneously off of one cell.
1 buzzer consumes 15mA.
The solar cell provides 50mA in moderate sun.
50mA / 15mA = 3 and 1/3 buzzers.
To keep things simple I stuck to one buzzer per unit.
For mounting purposes, I found a piece of scrap wire on the street. You could substitute any sort of wire including coat hanger wire.
Overall the bill of materials include:
1 X Solar Cell salvaged from solar garden light
1 X Piezo Buzzer
1 X Scrap wire
Tools to build this project are
A soldering iron
A glue gun
possibly a multimeter
25 comments
Dec 29, 2010. 12:13 PMxBRAZZMATAZZx says:
i made one it is really annoying
Apr 5, 2010. 1:19 AMKiteman says:
To turn this idea on its head, you could replace the annoying buzzers with something that plays an actual "note".
Several of them hanging in a small copse, each playing a different note, could be rather pleasant.
And for the intermittent idea, wouldn't a single flashing LED (FLED) do the trick?  If you don't want it seen, wrap it in insulation tape.
Sep 3, 2010. 9:11 AMMr. Potato Head says:
But it wouldn't be very funny if the sound was "rather pleasant". Not really what I would call a prank.
Sep 3, 2010. 10:18 AMKiteman says:
That's why I said "turn it on its head" - from prank to artistic installation.
Sep 3, 2010. 10:19 AMMr. Potato Head says:
Ohhh, now I get it! Sorry...
Apr 5, 2010. 10:22 AMKiteman says:
Current only when it flashes, I think.
Apr 5, 2010. 8:24 AMmasterochicken says:
When I first read your comment I thought it said corpse instead of copse. That would be an interesting prank.
Apr 5, 2010. 9:05 AMKiteman says:
...and a slightly disturbing funeral.
Apr 6, 2010. 9:28 PMmasterochicken says:
That would be fantastic.
Apr 5, 2010. 6:10 AMtrailleadr says:
Or make it sound like a cicada and do it in January.  Would really blow someone's mind how you would have cicadas in winter.
Apr 9, 2010. 4:57 PMincorrigible packrat says:
This one time, I heard a cricket on December 26 (and no, I had not been drinking... much)
It was a fairly warm Dec. 26.
The cricket was chirping reeeaalllyyy ssllooooooooowwwwlllyyyyy.
Nov 16, 2010. 4:44 PMbillythebob says:
ive heard u can tell the temp (dont remeber if in *F or *C) by how many chirp per minute/second
Jul 12, 2010. 8:07 AMthepaul1993 says:
How loud is it?
May 4, 2010. 4:07 PMzizou361 says:
Hmmm... if I try this, I think another possible placement for the device would be inside a light cover. When someone turns on the light, it starts buzzing, convincing them somethings wrong with the light.
Apr 7, 2010. 4:57 AMdvcrogers says:
What about replacing the buzzer with the guts from an "electronic birthday card"?
If that is possible, you could have a nice tune.
Apr 9, 2010. 4:53 PMincorrigible packrat says:
I wouldn't worry about that too much.  Those sorts of circuits only sound more "interesting" when the voltage is off spec.
Apr 9, 2010. 8:02 PMincorrigible packrat says:
Cool.   I was just thinking of a talking Alvin (from that cruddy Chipmunks movie) that I found at the dump the other day.  He's just crying out to be hacked for this or a similar project.  The neat thing about it is that at full power he says "hello gorgeous", but if you trigger him enough to run down the battery a bit, he just says "Hell"...
Apr 5, 2010. 1:01 PMitsthatsguy says:
5 stars, not only for having an original idea, but for using dell, windows FTW!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:drakesword(Satanic Spider Productions)
its not "look what I can do" its "look what I can teach you"
