Solar CHICKEN DOOR With Battery
1,545
20
Published
Introduction: Solar CHICKEN DOOR With Battery
Please check my previous Instructable, this is an upgrade so it runs off grid.
https://www.instructables.com/id/Automatic-CHICKEN...
Board and stepper motor are the same, the difference is in electronics as it is battery operated with solar charging. It consumes as low as 0.1mA thanks to LowPower library and cutting LED connection on the board so it doesn't draw current.
Step 1: Materials
-FTD1232
-Arduino pro mini
-5V Step Up Module(1)
-ULN2003A board (from previous Instructable)
-Li-ion battery (such as 18650) or 2xAA (see safe operating area pic) (2)
-0.5W 5V solar cell [outputs up to 7v]
-5V1 zener diode
-battery case
(1) For more reliability use separate charging board and step up module, down in alternatives. It is important to choose step up module with low quiescent current.
(2)If you intend to use AA alkaline batteries you may need to lower chip frequency and not connect solar power. Same with rechargeable AA, as they like to be discharged fully before changing (I think).
Some optional reading on low power Arduino:
http://www.home-automation-community.com/arduino-l...
Before going furter I advise you to download LowPower library:
https://github.com/rocketscream/Low-Power
Links to materials:
https://www.aliexpress.com/item/1pcs-lot-ATMEGA328...
https://www.aliexpress.com/item/5V-Boost-Step-Up-P...
https://www.aliexpress.com/item/Portable-Mini-6V-0...
alternatives:
https://www.aliexpress.com/item/1PC-LOT-TP4056-1A-...
https://www.aliexpress.com/item/DC-DC-2V-5V-to-5V-...
https://www.aliexpress.com/item/Solar-Cells-5-5V-0...
Use this extention to get up to 7% off
https://alibonus.com/?u=429363
Step 2: Getting Ready and Soldering
Cut the LED connection with a stanley knife to cut LED power. I don't think it's necessary to remove the voltage regulator(as suggested by the link) as we will be using solar cell to charge our battery.
Okay, here you may want to connect things properly, but I've cut some shortcuts.
I've bent (-)terminal on ULN2003A board to allign with IN1 to IN4 to solder Pro Mini directly on.
I've also mounted Step up Module directly beneath Pro Mini. A1 is used only as mounting pin. A wire is used to connect +5V from Step up to ULN2003A board. GND kind of goes through ProMini.
Add programming headers from GND to DTR. These will be also used later to connect the battery.
Solder pin4 and pin3 for photocell module.
Step 3: Connect
Wiring: (my wire colors)
ProMini
pin4 - VCC photocell (red)
pin3 - D0 photocell (brown)
Gnd - GND photocell (black)
Vcc - battery(+) (red)
Gnd - battery(-) (brown)
Solder Zener 5.1V 0.5w on Solar cell, then solder it to the end of microUSB cable.
Make a box for a Solar Cell and glue it inside so it stays dry. No need to waterproof it, just so it stays off the rain.
Step 4: The Code; Don't Forget the Low Power Library
#include "LowPower.h"
int Pin0 = 9;
int Pin1 = 8;
int Pin2 = 7;
int Pin3 = 6;
int _step = 0;
int t=2300; //increase if necessary, 3000
int sensorPower = 4;
int sensorPin = 3;
int sensorVal;
int revs = 24576; //equals 6 turns
int state=1; //0 is doors closed, 1 is open
boolean dir = true;// gre
void setup()
pinMode(Pin0, OUTPUT);
pinMode(Pin1, OUTPUT);
pinMode(Pin2, OUTPUT);
pinMode(Pin3, OUTPUT);
pinMode(sensorPower, OUTPUT);
pinMode(sensorPin, INPUT);
void loop()
digitalWrite(sensorPower, HIGH); //sends power to sensor
delayMicroseconds(1000);
int sensorVal = digitalRead(sensorPin); //reads sensor
digitalWrite(sensorPower, LOW);
if (sensorVal==LOW && state==0)
for(int i=0;i
state=1;
dir=true;
switch (_step) {
case 0:
digitalWrite(Pin0, LOW);
digitalWrite(Pin1, LOW);
digitalWrite(Pin2, LOW);
digitalWrite(Pin3, HIGH);
break;
case 1:
digitalWrite(Pin2, HIGH);
break;
case 2:
digitalWrite(Pin3, LOW);
break;
case 3:
digitalWrite(Pin1, HIGH);
break;
case 4:
break;
case 5:
digitalWrite(Pin0, HIGH);
break;
case 6:
break;
case 7:
break;
default:
break;
if (dir) {
_step++;
} else {
_step--;
if (_step > 7) {
_step = 0;
if (_step < 0) {
_step = 7;
delayMicroseconds(t);
if (sensorVal==HIGH && state==1)
for(int i=0;i
state=0;
dir=false;
switch (_step) {
case 0:
break;
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
case 6:
break;
case 7:
break;
default:
break;
if (dir) {
_step++;
} else {
_step--;
if (_step > 7) {
_step = 0;
if (_step < 0) {
_step = 7;
//sleeps for 8s*7=56s
LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
Step 5: Screw It in and Adjust the Trimmer
Now screw everything in and adjust the trimmer on the photocell module. Install the board in front of your coop and connect solar cell to the microUSB port and enjoy!
Automation Contest 2017
Runner Up in the
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    Cool and nice
