Step 2Overvoltage Disconnect
All it does is disconnect the panel from the battery when battery voltage goes over 14 volts.
Home Power Magazine Has published schematics for circuits that do the same thing.
You can still overcharge a battery through one of these units if your panel is big and your battery is small. The bubbling sound you hear in your overcharging battery is water (H2O) being broken down into hydrogen and Oxygen, which then bubble out to join the atmosphere. Eventually the battery will run out of water. Eventually the exposed parts of the battery's lead plates will oxidize and the battery won't take a charge, even if you add distilled water to it.
comment
Add Comment
Add Comment
