Step 3Low Voltage Disconnect and Inverter
It takes in 12 volts DC from the battery and produces 110 volts AC that I can plug my sewing machine, laptop, etc into. You can get them for cheap at any truckstop or discount store now.
This model has a low-voltage disconnect feature which is a big help.
When battery voltage drops below 11 volts it beeps and turns off.
That protects your battery from over-discharging.
Sulfating and De-Sulfating
If you run your battery down further than 10.5 or 11 volts, or if you fail to charge it up again soon enough, sulfate crystals will form on the battery plates.
The sides of your battery will bulge from the crystal deposits on the plates, and your battery won't take a charge anymore. There are tricks to fix this. Look up "desulphate", "desulfate"(both spellings are ok), "pulse charger", "battery edta". According to one vendor of desulfating products, 75% of the lead-acid batteries removed from service can be rejuvenated with these techniques. The others are suffering from shorts, open circuits, and similarly less correctable flaws.
To measure your battery's capacity
Plug in an mechanical electric clock and a known load, like a 5 watt lightbulb. See how long it takes to run down the battery til it shuts off. For example: 5watts/12 volts = 0.42 amps. If it takes three hours to discharge your battery after it's fully charged, your capacity is 3 * 0.42 = 1.26 amp-hours. (not very much) A typical emergency-lighting gel-cell has 7 amp-hours capacity.
comment
Add Comment
Add Comment
