Solar Car Charger in Dashboard
3,592
63
5
Posted in WorkshopCars
Introduction: Solar Car Charger in Dashboard
In this tutorial i show you how to install a solar panel in your car like it's made in a house.
With this you always have your battery full, this increase your fuel mileage and prevents to your battery drains when you dont use the car.
And even you can use the extra energy of the panel to put fans or some stuff in your car.
The Solar Panel is rated 9 watts and is monocrystalline
If you prefer you can see the Videotutorial
Sorry about my english, im from europe.
Step 1: Materials
You need a Solar Panel, Cable, and a Charge Controller , i use a MPPT because its more efficient, but also more expensive
Step 2: Pass the Cables
From the top of the dashboard to the glovebox and finally to the car lighter, or direct to the battery if you can do it this easily
In the dashboard the panel receives sun fine
Step 3: Hide the Expensive Stuff From Thieves
I paint the panel border and the solders to hide it better
Step 4: Connect All
in the charge controller appear drawings of how connect each wire
(Solar Panel + - // Battery + - // Use Energy + -)
You can see if works with the controller lights or a voltmeter.
The panel makes 17,9v in a cloudy day, and the controller send 12,4v to the battery to charge correctly.
Step 5: Rectification Diode
This make the energy goes in only one direction, and protect the panel if you put more panels.
(Correct direction: From panel to outside in the positive cable)
Step 6: Secures the Panel
This prevents it from moving or fall during driving
Now the battery does not go empty even if you do not use the car.
With the battery full, your car consumption is lower, and your alternator doesn't work so much.
And you can connect what you want to the 12v port of the controller.
For example a fan to sleep inside the car, lights or even a TV.
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    5 Comments
    Are you connecting the MPPT charge controller directly to the car battery?
    What's the voltage of your PV? From what I've read, the MPPT is really only effective if you're dealing with very high voltages (>100V)
    Otherwise, exactly the project I'm thinking about, just trying to decided if I want a separate bus so the system can power stuff while the car is off.
    I wanted to do this long time ago and remove the belt from the alternator during summer,
    Should be tested first for winter time
    But i just hate clutered wires and holes in my dash.
    Damn i wish my car had sunroof so i could hide the panel there.
    Nice work btw
    My car have sunroof, but is not clear/cristal and i dont want to glue the panel upside there.
    I dont need that diode now, but if i install other panel its better have the diode. Anyway i have power enought now.
