Here is my Solar Charging System and how I made it. What I didnt purchase, I recycled the parts from other things I already had to make it. I will show you each part of the setup and explain its purpose.
I probably dont have to explain the purpose of the solar panel, but thats where the electricity comes from. I am not sure about this, but I heard that one of the newest types of solar panels out there is the monocrystalline. I like it very much because it is small and it produces a lot of power. It may look big in the picture, but it is actually the exact same size as a 8x11 piece of printer paper.
Step 1: The Solar Panel Mount and Wiring
Here is the mount that I made for my panel, it actually came from an old TV dish so I took it off and re-used it for this project
Also in the other picture is my connection to the solar panel using a waterproof connector. Inside the red box is simply where I had to make other connections to the wire going into my room. The grey wire you see is meant to be used underground as it has 2 insulating layers on it. Also in the other picture, is the pole the panel is mounted on which is about 6 1/2 feet tall.
davecason says: Dec 12, 2011. 12:30 AM
Hi !
It looks cool, what size/power is your solar panel and where did you get the charge controller from !?
Cheers'
Dave
Electronics Man (author) in reply to davecasonDec 28, 2011. 4:23 PM
Hey, I got the solar panel and the charge controller off of Amazon.com and both were bundled together as one item. The panel is a 5 Watt which is small but works VERY well and is sold by the company Instapark.
Thanks!
Electronics Man
Electronics Man (author) in reply to davecasonDec 12, 2011. 2:15 PM
The solar panel is a small, but effective 5 Watts and its the same size as a sheet of printer paper. I bought it along with the charge controller off of Amazon.com
Thanks for your interest!
Electronics Man
Electronics Man (author) says: Aug 6, 2011. 9:21 AM
Hey triumphman, what you see in the first picture on step one is not actually a circuit board. As explained in the instructable, the solar panel is attached onto a TV satellite dish mount which I had to weld a piece of tin onto, so what you see that looks like a circuit board is actually the spatter from the welding. I hope that makes since to you. And for your other comment about the wiring, No I never did fry any components and it wasnt trial and error. But your right there is a lot of wires (There is actually more but you cant see them in the pictures) and I had an idea of what I wanted it to do so it made it much easier to build. And finally for your question about the cost, the only things that I bought was the solar panel and the battery. Everything else I recycled to make this setup.
Thanks for the comments and feel free to ask more questions!!!
triumphman says: Aug 6, 2011. 7:57 AM
How did you figure all this wiring stuff out ? Trial and error ? I would be concerned that I would fry too many components by the trial and error method! Can get expensive, Yes ?
triumphman says: Aug 6, 2011. 7:52 AM
In step one picture I can see a printed circuit board, is it exposed to the weather ?
vishalapr says: Jul 27, 2011. 10:07 AM
This is totally awesome! Well done on using green energy!
Electronics Man (author) in reply to vishalaprJul 27, 2011. 12:26 PM
Thanks!!
vishalapr in reply to Electronics ManJul 28, 2011. 11:41 AM
YUP TOTALLY AWESOME! Rated 5*****
vishalapr in reply to Electronics ManJul 27, 2011. 10:18 PM
(removed by author or community request)
ddavis662 says: Jul 27, 2011. 2:40 PM
Cool way to mount the solar panel
Electronics Man (author) in reply to ddavis662Jul 27, 2011. 7:51 PM
Thanks! The cool thing about it is that I can adjust the angle of the panel simply by turning a screw
ddavis662 in reply to ddavis662Jul 27, 2011. 2:54 PM
check out the charge my 15 watt solar panel is putting out.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
