My original instructable had a couple of flaws, some of them very important. I was originally going to post the updates on my first instructable, but there were so many changes that I had to make a whole new one.
Among these changes are:
- Overcharge protection (the main reason I wrote a new Instructable)
- Only one wire connecting the top to the bottom, not two little annoying ones
- No wires around the edges
- No annoying diodes where your hand goes
- You can get the stylus out now (I accidentally put a solar cell over it the first time, silly me)
This is my third Instructable, and if you have any questions, don't hesitate to post a comment! Don't forget to rate and vote either!
Remove these ads by
Signing UpStep 1Materials
- Four (4) 60 x 60 mm solar cells http://www.allelectronics.com/make-a-store/item/SPL-61/SOLAR-CELL-60MM-X-60MM-X2MM/-/1.html
- Two (2) diodes, almost any kind should work http://www.allelectronics.com/make-a-store/item/1N4001/RECT-DIODE-1AMP/50PIV/-/1.html
- One (1) Overcharge protection chip http://www.batteryjunction.com/prcimopfor3l.html
- Some thin wire (preferably at least two colors)
- Scotch tape
- Electrical tape
- 4.2 cm long piece of thin heat-shrink tubing
- Some ribbon
- Nintendo DS lite (really?)
- Hot glue gun with glue
- Soldering iron with solder
- Wire cutter/stripper
- Multimeter
- Helping hands tool (not required, but helpful)
- Solder Sucker (helpful if you mess up)
- Sandpaper
- Small phillips screwdriver
I know this instructable's a bit old but hopefully your still around to answer yet more questions :P
Thinking of implementing small solar cells into multiple gadgets and came across this:
http://www.dealextreme.com/p/si-solar-cell-panel-4-5v-5ma-12984
WOW 4.5V out of something so small ! but wait, theres a catch, the current is only 5mA :(
So my question to dark sponge is:
How important is the current in the process of charging small gadgets ? Would the lack of current be a worthy sacrifice for the extra voltage ?
If that ones a no goer than I do have a second solar cell in mind with higher current so no worries.
Cheers dude !
Edd Hewett
As I understand it (which is not very well) the Voltage is the amount of electricity and the current is the flow of electricity, so the 4.5V cell with 5mA current could charge a gadget (say a mobile with a 3.7V battery) on its own but really slowly. Whereas with a 2V 25mA cell you would need 2 cells to generate enough V to charge the phone but it would charge a lot quicker as it has a lot more current.
So. . .
Would it charge 5 times quicker as it has 5 times the current ?
I am assuming current does not stack like V so if you were to include both the different cells in series the result would still only be a current of 5mA and not 30mA. Is this true ?
Cheers
Edd Hewett
Any help would be greatly appreciated.
Thanks.
Thanks for the advice and awesome guide!
http://www.amazon.com/Weller-SP23LK-Marksman-Watt-Soldering/dp/B0009ZD2AG
