3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar DS "Light" Redone and Improved
Step 14Unite the Panels and DS Together!
  • last photo ←
Set the DS and the bottom panel right next to each other, and make sure the wires from the DS can reach the chip. Solder the positive DS wire (the blue one near the top of the battery compartment) to P+ on the chip. It should be the third wire being soldered to that terminal. Then take the negative wire from the DS (the blue one near the bottom of the battery compartment) and solder it to P- on the chip. It should be the third wire to be soldered to that terminal. Tape the wires down.
Take the positve battery wire (the red one near the top of the battery compartment) and solder it to B+ on the chip. It should be the only wire on that terminal. Now, before you solder the negative battery wire, test it with a multimeter to make sure there are no shorts. Set the multimeter to measure current, touch the positve terminal to B- on the chip, and touch the negative terminal to the negative battery wire. I got about .01 ma, because the DS uses a small amount of power in standby. Now do the same thing with the voltage setting, and you should get about 3 volts. This means that power is ready to flow through the DS. If either of your readings are way off, check your wiring. If you got them, proceed.
Take the negative battery wire and solder it to B- on the chip. It should be the only wire soldered to that terminal.
You are now ready to test it!
13 comments
Jul 22, 2011. 1:10 AMSteppenw01f says:
Hi, I got stuck at the final testing part, when I touch the multimeter's positive terminal to B- and its negative terminal to the negative battery wire, the voltage spikes to around 2 volts then drops back to 0. When I solder the negative wire to B-, the DS doesn't turn on either. If I touch the negative terminal to the positive battery wire and back to the negative battery wire, it repeats the same behavior. I've checked my wiring repeatedly, everything seems fine as far as I can tell. FYI I'm using the PV cells, overcharge circuit, and diodes you listed on my original DS.
Any help would be greatly appreciated.
Thanks.
Jul 25, 2011. 11:40 PMSteppenw01f says:
I just set it up on my SP also, can't wait for a sunny day!
Jul 25, 2011. 4:47 PMSteppenw01f says:
Messed around with it some more and it turns out the DS wouldn't turn on even with the battery directly plugged in : (, but I wired the battery back to the circuit and the circuit to another DS and it turns on fine! I'd test it right now, but it's rainy here and the forecast says it won't be mostly clear until at least Wednesday. I'll be sure to post a pic when the sun comes out.
Thanks for the advice and awesome guide!
Jul 26, 2009. 2:35 PMfernxtwo says:
hi there im in middle of this instructable and have hit a little snag ,
on my over charge chip i can't find a p- or p+.
it just has b- and b+ .
you can see it here, did i get the wrong chip or am i reading it wrong?
http://fernxtwo.googlepages.com/P4301166.JPG
thanks.
Jul 26, 2009. 5:46 PMfernxtwo says:
no it wasnt the one you listed , because that website doesnt ship to canada , so this is where i got it:
http://dealextreme.com/details.dx/sku.26114
and heres two pics of the reverse of the chip , it's just metal with 4 tiny holes on it.
http://fernxtwo.googlepages.com/P4301168.JPG
http://fernxtwo.googlepages.com/P4301169.JPG
thanks.
Jul 27, 2009. 8:26 AMfernxtwo says:
thanks for the help. just one more question.youy say if the battery drains compleatly i might not be able to charge it again , but if i remove everything from my ds it'll be back to normal will it?i mean like is this going to damage the battery? cheers.
Aug 4, 2009. 9:22 PMfernxtwo says:
okay so i just did everything in the diagram , and i was just wondering how long does it take to charge?
Aug 11, 2009. 9:25 AMfernxtwo says:
okay , finally finished the solar DS . looks good , works well. i must put up a couple of pictures. one more question.how do you get the stylus out? i had to cut a little piece out of mine , cause my cell covered it a bit.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
72
Author:dark sponge
Hi! I've loved electronics and electricity for as long as I can remember, and electric projects are something I do in my free time for fun. Everything I've learned about electricity is either from exp...
more »
