3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar DS "Light" Redone and Improved
Step 17Option 2
Option 2
In my previous instructable, many people were saying they wanted to build a base that would stay in the sun all day collecting power and transfer it to the DS overnight. So I came up with a schematic for a device like that.
This switch changes between charging the battery from the solar cells and transferring the charge to the DS.
12 comments
Apr 17, 2011. 12:16 AMZeroXL91 says:
Wait, so like that guy said, is it possible to have a battery that can charge with solar and DC power?
Mar 30, 2011. 9:26 PMwinter-chaos says:
I need to reduce the voltage down to 4.5 or 4.6 volts for the DSi, any suggestions how I can do that....
Apr 13, 2011. 10:43 PMwinter-chaos says:
thanks that helps alot, ^^.
Aug 3, 2010. 5:41 PMpyro2992 says:
On the switch isnt there normally only 3 prongs? two positive one negative, could you please calrify how you would set this up and on what kind of switch
Jan 20, 2010. 11:03 AMInfraBlue says:
Will a 150mAh 9v battery be able to charge my 1200mAh ds battery?
Mar 30, 2010. 10:08 AMInfraBlue says:
Thanks
I have found a more efficient way to charge the ds battery.
Diagram
Hope this helps
Mar 31, 2010. 8:26 AMInfraBlue says:
I have made this and it works. The NiHM batterys have around 1.2v so it is producing about 5v. Intstead os a DS jack i put an USB socket there so i charge different stuff e.g mobile phone, xbox 360 controllers.
Jul 22, 2010. 4:54 PMMacworldwizardz says:
Is it possible to overcharge the DS battery while charging an USB product (ie. iPod)? I am really curious, Because I know how light is converted to electricity. Also, how many solar cells do you think the solar panal carries?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
72
Author:dark sponge
Hi! I've loved electronics and electricity for as long as I can remember, and electric projects are something I do in my free time for fun. Everything I've learned about electricity is either from exp...
more »
