Remove these ads by
Signing UpStep 1Materials
- Solar Cell (preferably 1.2V or higher; you can probably get one off Amazon for $7; the one I'm using is a 6V I got from Radioshack for $16)
- Cup or container (sorry that mine is so dark, it was all that I had)
- Wire
- Capacitor (optional; you can get one by harvesting a disposable camera)
- Soldering Iron & Solder (optional; makes things WAY easier though)
- Tape
*fun idea* adjust your water container to accept a balloon on the top so you can fill it with a perfect molar ratio of H and O. When the balloon fills up, tie the end, then tape on a piece of cannon fuse. Light. Release. Plug your ears. and only do that under competent adult supervision....
The 2 H2O(l)→2 H2(g)+O2(g) reaction , when reversed, produces HEAT energy aka it's flaming gasses! No measurable electricity produced.
Although the chemical reaction SEEMS simple enough... there are actually a few half-reactions involved, that prevent a true two-way reaction. That's why you need flame/spark to reverse the equation. It is just for the sake of simplicity and brevity, that we write the equation the way we do.
Also note, PURE water(distilled, de-ionized) will NOT work, especially at the low voltages produced though consumer grade solar-voltaic cells.
Final experimenters note.
Never EVER run this with the cap on.
When the water being split is in an enclosed container, what you have is a BOMB! :-)
Sure, that can be fun in and of itself, but you need to treat it as such.
To help stave off arguments... here's the half-reactions ACTUALLY involved(well, ONE of them, as best explained by http://en.wikipedia.org/wiki/Electrolysis_of_water)
2 H2O(l) → O2(g) + 4 H+(aq) + 4e−
2 H+(aq) + 2e− → H2(g)
initially, you would just have the gasses building up pressure, till the vessel ruptured.
The severity of the rupture is directly proportional to the container.
Small film canister, with the press on lid, not much worry. after a few psi, it'll just go "pop" and the lid will partially come off. Screw-on-lids, glass jars, metal containers... all a fair bit worse, when the give up their structural integrity.
then you have a concentrated ball of highly flammable gas, and pure oxygen, waiting for the least little spark, heat, or flame, to turn into a proper explosion.
This danger increases, the larger your container, and the greater pressure.
these qualities allow MORE gas to build up before the potential explosion.
More gas = bigger boom = more dangerous :-)
