Solar Gameboy Advance
Give your Gameboy Advance a little solar power.
Step 1Get supplies
You will need:
1 Gameboy Advance (the original one not the SP or Micro)
1 Solar Panel (from garden lights)
1 Switch (optional yet recomended)
1 Diode (definatly NOT optional)
1 Voltage Regulator (only optional if your solar panel can't give out more than 6 volts)
A little bit of spare wire
47 comments
1-40 of 47next »
Feb 21, 2011. 12:54 PMShadowAssassin says:
Could you do this with a gameboy advanced sp?
Nov 28, 2010. 5:55 PMtoogers says:
very nice, my solar panel was a little overpowered so i mae it also power some LEDS to make a backlight.
Sep 20, 2007. 11:45 PMandrew93 says:
where did you buy that solar panel? i'm looking for a big one but all i found is a small one!!
Apr 28, 2008. 3:42 PMcoolz says:
it HAS to be small, dude
Jul 2, 2009. 5:44 PMReCreate says:
A small one will provide almost no electricity...
Nov 28, 2010. 3:15 PMtoogers says:
but you don't want to carry a whole power plant with you, am i right?
Apr 22, 2008. 4:24 PMfwjs28 says:
or a 3v calculator solar power
Feb 3, 2010. 10:51 AMAntMan232 says:
 Isn't a more complicated circuit needed to charge the batteries properly though? I don't know, but surely there should be more than that.
Jan 11, 2010. 2:38 PMMadrias357 says:
You don't just have to use NiCD batteries: I've charged NiMH batteries with this type of setup.
Nov 1, 2006. 4:04 PMBad Donut says:
Cool, but, who plays gameboy advanced anymore? Maybe you should have used this on an Ipod or something.
Sep 7, 2009. 2:17 AMJais1993 says:
I just whipped out my old GBC.
Aug 11, 2009. 9:49 AMSypran says:
i love my advance! it plays gbc games, sure the sp has a back lit, but it was to small for my hands
Jul 9, 2009. 3:40 PMmasterochicken says:
I do. Now STFU.
May 27, 2009. 5:54 PMzitz says:
I play my gameboy games on my gameboy advance because it's more portable than my snes
May 10, 2009. 11:28 AMn0ukf says:
Where is the photo of the completed project? Everything's still open.
Also, there is no schematic (wiring diagram) in this project and you don't identify the type of regulator (what voltage and polarity).
Jun 10, 2009. 11:30 AMn0ukf says:
Please edit your parts list to specify the regulator for those that don't know the difference between one and another. the way you list it (unspecified), it doesn't appear to matter what voltage or polarity the regulator is. LM7805 is +5v and LM7905 is -5v regulator. Other variants are the LM78L05 low power regulator. And you're still missing a wiring diagram (schematic). The photos aren't totally clear on the connections for those who don't already know.
Jul 2, 2009. 5:43 PMReCreate says:
Lol, The 5V regulator is Realy unnecessary, the cell voltage never goes higher than 3V, and the solar cell does not provide any more than 40 MA, going through the regulator, The gameboy is probably getting .5-2 volts at -5Ma...
May 4, 2009. 7:37 PMfang113 says:
do you have to solder? and if not, what else could i do?
May 5, 2009. 5:54 AMfang113 says:
thank you for the info, i dont have a soldering iron
Mar 3, 2008. 9:23 PMn0ukf says:
One thing you neglected to mention in supplies is the 3-wing phillips security screwdriver to open the GBA. I found mine on ebay, along with the bits for the other Nintendos and cartriges.
Apr 18, 2009. 9:41 AMjillg says:
if you're using the gbc instead of the advance you just need a regular phillips.
Oct 5, 2008. 5:58 PMSypran says:
does this remind anyone of boktai? ooo i just got an idea! devote one of my gameboys (my D pad damaged one peferably to solar colecting wile being solar powered
Feb 10, 2009. 1:48 PMqwerty29 says:
yep
Jun 23, 2008. 9:03 PMTheWelfareWarrior says:
ha ha! that is EXACTLY the same solar panel that I have! But mine isn't in use at the moment... How many Watts does the GBA draw? I was just thinking about doing this to one of my old gameboys and was wondering what a ball park estimate would be.
Apr 29, 2008. 2:43 AMandrew93 says:
yeah i know but i don't want it for the game boy, i want it for other stuff!!
Apr 22, 2008. 4:28 PMfwjs28 says:
or u could just connect them to the battery terminal and use the calulator solar panel i suggest(see below) which is 3v....and then u could play like that....
Apr 15, 2008. 3:22 PMCapnTac says:
Could this work for a GB Color? Not that I own one, but I'd rather go out and buy an 8 dollar color than a 20 dollar advance just to try this project, because I already have a DS.
Oct 24, 2007. 11:34 PMPCvsMac says:
Nice... But surely it must be easier to wire it upto the + and - Terminals by alligator clips? Also, Great project, nice to see that people do care about the world (No offence to anyone who reads this)
May 24, 2007. 9:20 PMZlwilly says:
that makes sense, good to know. I'm buying a few packages of solar cells for a new project, set up with a nice little voltage regulator it should make a pretty good first instructable once it's finished. Thanks for the info, nice project.
May 24, 2007. 7:13 AMZlwilly says:
well solar cells have a constant voltage, (correct me if im wrong, im new to this,) so it seems like all that really matters is the current the cells can kick out. A solar cell's output is measured in Amps or Watts, so as long as you know how much energy you need, you can kick it through the right voltage reg and your all set!
Nov 2, 2006. 6:26 PMSinner3k says:
Anybody have the cajones to crack open an SP to see where the connections are on that? This would be great for my boy who leaves his SP laying around for days on end and never remembers to attach it to the charger. The trickle charge would keep it ready to play pretty much whenever he gets the itch to.
Oct 31, 2006. 1:49 PMSilas says:
I like the idea. Crash2108: You wouldn't..
1-40 of 47next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
72
Author:bmlbytes
A current student at the University of Advancing Technology. Currently studying Robotics and Embedded Systems.
