loading
I made this solar generator to power lights, a radio and recharge batteries for my trip to Burning Man 2008.
Parts list:
1. Sunforce 15 watt solar charger with with 7 amp charge controller - Kragen Auto - $99.99 part #50033
2. Pro X One 800 watt power inverter - Kragen Auto - $49.97 on sale - part #64009624
3. Nautilus Gold 24 NG24 deep cycle battery - $84.99 - Kragen Auto - part #6228613
4. 12 volt outlet (cigarette lighter type) - 10.99 - Kragen Auto - part #6261044
5. Digital multimeter - $2.99 - Harbor Freight Tools - part #90899
6. Crimp style electrical connectors (butt and 3/8" ring) - $2
7. 1/2" plywood (or whatever you have lying around) - $10.00
8. Hinges, handles, latches and screws for the box - $15.00
9. Eight zinc plated "L" brackets - $5.00
Step 1: Buy the Parts
I got most of my parts from Kragen Auto. They'll give you a 10% discount if you ask. I had some 1/2" plywood left over from another project to build my box but I saw that RoDuS1488 used a small cooler for his solar generator...that's a great idea, especially if you don't have wood working tools or just can't wait to get the party started. The solar panel comes with a fifteen foot cord that seems long enough to keep the panel out of the shade. Multiple panels can be wired together to get more power. One 15 watt panel barely keeps the battery charged. I think two (at thirty watts) would do a little better.
Step 2: Build a Box
I built my box out of 1/2" plywood and reinforced the inside corners with zinc plated "L" brackets. The sides have heavy duty chest handles to carry the generator and the bottom has four zinc plated metal corners to protect the bottom. The lid is held on with two hinges in the rear and one latch in the front. I made the box 1/2" bigger than my battery around the sides and 2" taller. I also drilled one inch holes in the sides to vent hydrogen gas and allow the battery to cool.
Step 3: Connect the Wires
Put the battery in the box and connect the wires. I cut the ends and used 3/8" ring crimp wire connectors to run the wires to the battery terminal posts. My deep cycle battery has four posts...two are standard car battery type posts and the other two are threaded studs. I used the threaded studs for a more secure connection. Connect the red terminal from the inverter to the positive post and the black to the negative. The solar panel connects to the battery through the charge controller. This keeps the battery from over-charging. The controller shuts off at 14.2 volts and comes on when the voltage drops below 13 volts. I also added a 12 volt outlet directly to the battery for use with cigarette lighter adapters. There's a two amp inline fuse on the positive lead. I bought a cheap digital multimeter and zip tied it to the top of the battery so I can monitor the voltage usage. I cut the leads and again used 3/8" ring crimp connectors to permanently connect them to the battery.
Step 4: Plug in and Enjoy Clean, Silent Power!
I'll use the generator in my dome to run white LED Christmas lights, satellite radio and to charge batteries for my camera and ham radios. )'(
Update: The generator worked great. It never ran out of power. I use it every day at home now.
Does anybody know a site or what information I would need to gather to figure how much battery and watts I would need to run a selection of things? I am wanting to build something similar to this for my own family camping needs and would like to run a couple small tent fans, a small 12v mini fridge, and maybe a cell phone charger or two. I can get the power requirements for the items just want to know how to judge the size of my requirements.
Once you have converted doc to ac then use killawatt to measure your real time ac wattage.
Figure out each item's power load in amps and judge that total against your battery's amphour rating.<br />
<br/>Wattage of Common Household Appliances/Tools<br/>Appliances<br/> <br/>Resistive Load<br/> <br/>Reactive Load<br/>Blender<br/> 375 watts 500 watts<br/>Clock Radio<br/> 5 watts ---<br/>Coffee Maker<br/> 1,700 watts ---<br/>Computer - PC<br/> 300 watts ---<br/>Cuisinart<br/> 450 watts 650 watts<br/>Deep Fryer<br/> 1,800 watts ---<br/>Electric Blanket<br/> 400 watts ---<br/>Electric Curlers<br/> 300 watts ---<br/>Frying Pan<br/> 1,250 watts ---<br/>Hair Dryer<br/> 1,875 watts ---<br/>Iron<br/> 1,200 watts ---<br/>Light Bulbs<br/> see marking on bulb <br/>Microwave<br/> 1,050-2,500 watts ---<br/>Washing Machine<br/> 1,150 watts 2,200 watts<br/>Water Heater<br/> 4,000 watts ---<br/>TV - Color<br/> 300 watts ---<br/>Common Tools<br/> <br/>Resistive Load<br/> <br/>Reactive Load<br/>Air Compressor (1hp)<br/> 1,500 watts 4,500 watts<br/>Cultivator<br/> 700 watts 1,400 watts<br/>Freezer<br/> 800 watts 2,100 watts<br/>Furnace Fan<br/> 875-1,200 watts 2,200 watts<br/>Garage Door Opener (1/4 hp)<br/> 550 watts 1,000 watts<br/>Grinder, Bench<br/> 1,400 watts 2,450 watts<br/>Heater, Kerosene (90,000 BTU)<br/> 500 watts 725 watts<br/>Sump Pump (1/3 hp)<br/> 800 watts 1,250 watts<br/>Well Pump (1/2 hp)<br/> 150 watts 1,950 watts<br/>Saw, Band<br/> 1,100 watts 1,350 watts<br/>Table Saw (10 inch)<br/> 1,750 watts 4,250 watts<br/><br/>the chart is on <a rel="nofollow" href="http://www.askthebuilder.com/B178_Common_Wattage_of_Household_Appliances.shtml">http://www.askthebuilder.com/B178_Common_Wattage_of_Household_Appliances.shtml</a><br/>
Isn't 800W inverter too powerful? I mean, 15W solar panel produces much too little for powering anything in the range of 800W. While you are not able to power big devices, you power small devices at higher losses - high power inverter means higher no-load current, which can take a lot of energy over time. So I would suggest to use smaller, say 300W inverter or even less :)
And I would suggest using Kill-a-watt to help with your addition so that you can ensure the math is right before buying an inverter- count up how many watts you plan on using on all your devices and get an inverter that will cover a continuous load for that rating.
There are inline fuses. You can see one in the pictures. The solar panels are pretty cheap. They aren't very powerful, since the time of the project, the prices have gone down for better panels.
I recognize that multimeter from harbor freight. Nice- because with a coupon they are free. I have Harbor Freight's 45w kit and a 7a charge controller. The problem ai have is that it is not water resistant. I never would have thought to tie in the multimeter to be used as a digital gauge. Genius!
<p>I think you need to take some time and go to inplix website to learn how to make it.</p>
<p>Not bad. I would have used a larger solar panel to power more things. And for safetys sake add an inline fuse between each part. Cheaper to replace a fuse than anything else</p>
<p>Cool!</p><p>My first Questions is, Where did you get that dome tent? 8 )</p><p>I love it(the dome)!</p><p>I also love the idea of how simple &amp; easy it is to build this thing...</p><p>I don;t know why, but I always thought that these were a very complicated thing/project....</p><p>Obviously I was wrong.</p><p>TY for sharing!! : )</p>
<a href="http://www.harborfreight.com/solar-panel-kit-45-watt-68751.html" rel="nofollow">http://www.harborfreight.com/solar-panel-kit-45-watt-68751.html</a>I have found this set at harborfreight.com they also sell a deep cycle battery for about $60 to $80 depends on the sale.
Long can
How many hours did it run the lights, radios and camera battery chargers?
It would run them all night and have plenty of power left before the sun came up to re-charge the battery. I used LED Christmas lights that only used a few watts and I don't think the battery charger used too much power.
Awesome, thanks for the info. I am looking for something to power my laptop, a box fan and small refrigerator. Would I have to modify yours much in order to power all that?
I think it could handle all that. My friend has a 12 volt refrigerator/freezer in his FJ Cruiser running off a deep cycle battery. It doesn't seem to use too much power. He has a dual battery system, one deep cycle for accessories and one regular battery for starting the car. The laptop and fan shouldn't drain the battery either. If you can get them all to run off of 12 volts instead of using the inverter, you would probably use less power.
I'm not great at electronics but I think it depends on the laptop.. Mine has an adapter that outputs 19v therefore I think I'm correct in assuming it would need more than this setup to run it. Could be wrong though!<br />
Just because it charges at 19v dosen't mean that a DCDC converter wont work, i bet if you check your BATTERY, it should say like 10.2 or 10.8v.
Great post!! &nbsp;I have been looking at setting something like this up for a while. &nbsp;I know this is an old one, but I was wondering if there was a way to add a battery charge indicator to quickly see how much life is left between charges.<br />
Hey, i couldnt help but read your comment, but i just recently found a PV charge controller for 80 dollars.<br /> It can handle up to 50 volts and or 12 amps of current.<br /> Its a Prostar 12.
hi TRK im planning to build a light emergency sistem using leds as a normal lights but i´like to have at least 5 leds in differents parts of my home the question is how i can power them and last 2 or 3 days what battery i can use ¿ can i use a battery car? thanks
The best battery is a deep cycle one. There is an Optima yellow top deep cycle battery (for cars & stuff) that does not vent when charged because it is sealed. So that means no harmful vapors to worry about when it is charging. It is deep cycle so it will last longer and charge better, even from a complete drain it will charge right back up.
Hey, I am building a pedal generator bike with a battery. at the end of the day i want to transfer the electricity i made of riding into a bigger battery and then use it for lighting equipment... anyone knows of a method to transfer the electricity from one battery to a bigger one without losing voltage or too much energy???
You could have the generator running through to a charging batterie and then use that battrie to charge the others but you would lose power that way.
I saw an artical in <em>Popular Mechanics</em> (I think) The guy used a bike tire generator to run off a water wheel that he jammed into a stream bed. As the water flowed he recharged his batteries. 24 hrs a day, no need for sunshine. Of course you have to camp near a running stream. <br/>
That's incredible.
Wicked!
try using a small battery that u can just disconnect when u r done that eliminates alot of cost and hassel try <a rel="nofollow" href="http://www.all-battery.com/nimhnicdpacks48v-60v.aspx">here</a>they have alot of interesting batteries to chose from, and u can even design your own pack!<br/>
I don't think those batteries would run the inverter.
Thanks, Man. Eric D.
can i use a car battery with two standar posts
Yes, but a deep cycle battery will last longer and handle the battery drain better.
How is it possable that this instuctable was posted Aug. 5, 2009 (today) and there are coments from 2008?
....thats when it was last updated.... ....look to the right where it says "more info"....
How long does it take to recharge the battery, and how many amp hours does the battery hold?
I've never discharged it all the way. It was 13.3 volts when I bought it new and the lowest it's gone down has been 12.5 volts. It takes a whole day of sunshine to charge it back to 13.3 or above. The regulator cuts off charging at 14.2 volts but I've never seen it get that high. The battery is 80 amp hours.
very nice you could increase the battery life by hooking up two batterys in line
I like this. Also, big thanks for adding a parts list w/ serial numbers!
Thanks, I don't know if the Kragen part numbers are still correct since they were recently purchased by O'Reilly Auto, but they still may help.
great write up, I'm planning a similar set up for this year. You mentioned that one panel barely kept the battery full; any plans to up the panel to two or more this year? I'm thinking about this system from costo: <a rel="nofollow" href="http://www.costco.com/Browse/Product.aspx?Prodid=11298162&amp;search=solar&amp;Mo=21&amp;cm_re=1_en-_-Top_Left_Nav-_-Top_search&amp;lang=en-US&amp;Nr=P_CatalogName:BC&amp;Sp=S&amp;N=5000043&amp;whse=BC&amp;Dx=mode+matchallpartial&amp;Ntk=Text_Search&amp;Dr=P_CatalogName:BC&amp;Ne=4000000&amp;D=solar&amp;Ntt=solar&amp;No=8&amp;Ntx=mode+matchallpartial&amp;Nty=1&amp;topnav=&amp;s=1">http://www.costco.com/Browse/Product.aspx?Prodid=11298162&amp;search=solar&amp;Mo=21&amp;cm_re=1_en-_-Top_Left_Nav-_-Top_search&amp;lang=en-US&amp;Nr=P_CatalogName:BC&amp;Sp=S&amp;N=5000043&amp;whse=BC&amp;Dx=mode+matchallpartial&amp;Ntk=Text_Search&amp;Dr=P_CatalogName:BC&amp;Ne=4000000&amp;D=solar&amp;Ntt=solar&amp;No=8&amp;Ntx=mode+matchallpartial&amp;Nty=1&amp;topnav=&amp;s=1</a><br/><br/>
those wires look way to light weight for an 800 watt inverter that thing can pull over 65 amps from the battery continuously at full power.
Those are the wires that came with the inverter. The two 10 gauge wires go from the battery to the inverter, the other 16 gauge wires go to the 12 volt cigarette lighter outlet, the volt meter and the solar panel (through the voltage regulator).
oh yeah for the HHO generator. i'm working on it wight nao. so i think i should change it nao
how much does the sunforce solarcell? Tks b4.
It puts out 15 watts.
Nicely done! Interestingly enough, I'm halfway through a write-up (I started two days ago) of my own project that is <em>very</em> similar to this. Great minds think alike! <br/><br/>Cheers!<br/>
i could use this for hho generation
This looks like a red head step child of my Instructable. <a href="https://www.instructables.com/id/Solar-Power-System/">https://www.instructables.com/id/Solar-Power-System/</a><br/><br/>But, adding the multimeter and cigarette outlet are nice features.<br/>
Thanks Mr. Chicken...
About This Instructable
90,508views
901favorites
License:
More by tk1314:Hard Hat Fan Vans Roller Skates Kindle Cover
Add instructable to:
