3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar Heater
Step 4Cut Vents into Wall
Cut Vents into Wall
Cut the holes in the wall like in the diagram, a vent on the bottom and on top for each stud section. Watch out for electrical wiring, etc.
My vents are 4" x 16"
The cuts are not pretty, use foil tape to trim the inside edge of the vents
This was the toughest part because I didn't have a good saw.
2 comments
Feb 22, 2007. 6:17 PMjeremy776655 says:
Hello, I am a big advocate of DIY but this piece should at least mention the lateral strength reduction which occurs if you do this. OSB or Plywood sheathing is a major part of most construction's earthquake strength. Holes drilled and spaced out would significantly improve this design from a structural perspective as long as you know where the studs are located. For a garage or chicken coop this isn't generally as important as in the case of a house. As you mentioned, preventing the warm air from leaving at night should be a required part of this design. Jeremy, United Brotherhood of Carpenters Journeyman
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
192
Author:robbtoberfest
Stay-home Dad. I like solar energy, boating and sailing, making stuff, melting stuff, and raising chickens.
