Step 6Install Glazing and Vent Valves
On the top vents in the building you'll need to put a flapper valve made from plastic sheeting or a trash bag, this keeps the warm air from leaving at night as the heater would work in reverse. Also put some screen on the vents to keep most of the critters out and to keep the plastic valves from sucking into the vent.
Extra notes
Using recycled wood and some on-hand hardware, I spent around $100 for this; now I'm enjoying free heat.
Ducting with a fan and a thermostat switch is what they use on commercial versions installed on homes. That works well for precise heat control. I like convection, no moving parts; and I will just close the vents when the weather gets warmer with some cardboard stapled to the wall.
menards has some panels but the ones they call clear are more like bathroom glass and the only other ones that would work are smoke colored and i dont think that would allow all the light waves in to the heater and therefore may not allow it to heat as much
Do you have any (water) leaks now that you've used it awhile? And how hard is it to shut off in the summer?
For this design, I would imagine that the length of pipes would be about equal to the space (maybe an inch or two less) in between the top and bottom vent holes.
Well that's the theory if I have it right.
That has given me another idea. Why not use that heat input to the roof space to be used. Have a vent in the roof which can have a variable size exit and allow air to rise from inside the building at the same time allowing colder air in from low down in the building. A cheap air conditioner? Could even have the vent controllable by some thermostat system if it was good enough.
