loading
Step 15: winter testing
Snowy morning in Washington. Made it to 110 before noon. Outside temperature got up to 55. It reached 130 in the hottest part of the day. I think the reflection off the snow helped raise the temp. today. The last picture is all my experiments. In front is a small solar panel I made out of 20 broken garden lights. I will start an instructable on it next week to enter that contest for the laser cutter. Next is a solar water panel that heats a 50 gal tank under the bathroom floor and radiates heat out all night. Behind that is this instructable, behind that is my solar oven.
<p>Very excited to try this. Do you have any safety measures to suggest if the temp goes dangerously hot?</p>
What a great idea! I am considering trying a solar heater for my pool(30 ft,round, 52" deep, approx 10,000 gals) I am only looking to pick up about 10 degrees to 75-85 F. Do you think this is feasible? would a batch style be the most effective? Would an old water heater tank be large enough? I have unobstructed sun all day. All comments or suggestions would be greatly appreciated.
This combined with perhaps fresnel lenses, or parabolic mirrored dishes, etc, could theoretically give you near boiling hot water on demand as long as you tracked the sun with it. However the addition of a tank would allow for hot water at night, and would help make sun tracking far less critical. See Kingofawesome's Fresnel lens projects.
Hi I think your idea sounds OK. I would try for a least 30 gallons and a larger box, about the size of an old sliding glass door. I see them in garage sales all the time. Getting the correct curve would make it heat better also.I just used what size I had available. Insulate as good as possible and double glass if you can find it. I am very happy with the output of this one, on nice days I don't turn on the electricty to my main tank. Good Luck with your project.
Thanks for the input. I'm finalizing plans now and will hopefully install and test late April/early May and will post results.
I have a 28,000 gallon pool in NJ with all day sun (when it's shining). I was about to buy a $150 solar collector panel (black poly with many individual channles..made for pools)to test functionality and was poking around for DIY ideas instead. Did you have any luck building this? I'm curious how the constant flow you'd have with a running filter impacts the ability to heat the water...ie is the flow too fast for the collector to warm it up?
Hey I've thought of this too, was wondering if it would be better to make something with more surface area, using black hose, since the water is flowing constantly. I've seen models that go on a roof with small black hoses. My idea was to use a hose run back and forth inside a box like this,
THere is another way to want to warm your pool. Cover the pool so you decrease the evaporation. The change of state of water consumes many more calories then radiant heat loss. I have even heard of nets holding foam blocks that just decrease the surface area which loses heat by evaporation.
you want a layer of foil on every household roof. With the foil reflecting the light into the center of the street, warming your thing in a cylindular form.<br />
Very nice design for the pre-heater. I'd like to build one to pre-heat the water that goes into my automatic dishwasher, to save the electricity that the washer uses for pre-heating. It would need to heat 4-5 gallons to 140-150 degrees F. I&nbsp;think the most difficult part would be the plumbing.<br />
excelente id&eacute;ia. temos muito sol aqui no brasil e ir&aacute; funcionar muito bem!!!
i love this site -- i love you guys -- i.........I'm getting carried away here -- good job !
The nice thing is it costs little to build, less to maintain, and nothing to operate. Even if you build a system that just suppliments your present system, every bit of energy you harvest is money saved. It amounts to turning sunlight into money! Thanks for sharing your expertise with us.
Great Idea!
Looking forward to more info on the floor project, any progress?
Hi Not much progress on this project. It was working great for a few months but I had to drain it in this freezing weather. I have some small leaks so I won't put the RV antifreeze in till I get new hoses. I added a remote wireless temp. unit so I can monitor the water temperature from the living room. I will take more pics and start a new instructable when the weather clears up.
Very cool... er, hot! I would like to have seen how you hooked it into the plumbing with a diagram and some pics.
I will surely be waiting for that instructable! Theres nothing like a warm floor on a morning shower! Thank you!
I would love to see if this could be applied to a "home made radiant heat system" for a crawlspace.. use the tank to heat the antifreeze and have it circulate through the radiant heat piping.. would it be a direct connection? i am seriously wanting to do this to add heat to my kitchen and bathroom floors, or make the crawlspace air less cold....
Hi I just added a pic in view 12 that shows my new panel that I got for free on freecycle dot com, just had to solder a few leaks. It heats a tank under the floor. You could use a batch type heater also and get the same results maybe better as there is more storage.
Great i'ble, simple, cheap and very green! Well written too.
Yeah, this is awesome. Imagine one of these in every home, the savings would be incredible.
Great job, 5/5
About This Instructable
79,812views
178favorites
More by aleutianwind:solar lens from TV hand tools Cigar box guitar Solar pop can heater
Add instructable to:
