3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Best damn organic recycled solar pump hydroponic system
Step 6Install Feed Lines
Install Feed Lines
Here we will install in each plant box the 3/8" tubing that runs the length of the box.
Drill two 3/8" holes just above the media on opposing sides (lengthwise) of each of the media-filled boxes. Pass the tubing through the first hole and feed it out the other.
In this system, the irrigation and drain tubes are on the same side. On the opposite side, you'll need to have 3" extra of poly tubing so that you can bend the tube back on itself and secure it with a cable tie, making them leak-proof.
1 comment
Aug 21, 2011. 3:31 PMxWildCardx says:
Might as well just connect all 3 boxes on the backside to. This will help match (precipitation) thru all 3 boxes.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:YotaTruck
