Introduction: Led Circuit Solar Powered
About: Rotating magnetic fields generator research, electric motor, electric generators, electric vehicles
Objective : to build a small solar lighting system without to store energy, composed of solar panels, step-up module and led circuit.
a sciencetoolbar project http://sciencetoolbar.com
Step 1: Materials Used to Build Solar Lighting System
1.Small solar panels – 2 peaces
Solar panel 0.5 W 5 V max.
2. led circuit ( 5 leds )
The led is known for the low power consumption.
3. step-up booster
Type: Switching type DC-DC Step Up Boost Module; Model: XL6009
Input voltage: 3-34 V. Output voltage: continuous adjustable (4-35 V). Output current: 2.5 A (MAX). Input current: 3 A (MAX). Input methods: IN + input is level, IN-input negative. Output way: OUT + output is level, OUT-output negative. Adjustment: first correct by input power supply (3-34 V, between) Output voltage: 4-35 V continuous adjustable Dimentions: 45 x 20 x 14mm Weight : 11gr
4. wires
Step 2: Operations :
Connect solar panels (dc voltage) to the step up booster input through wires.
Connect the led circuit ( dc voltage) - 5 leds to the step up booster output.
Step 3: Important Note !
If you will connect the led circuit directly to the solar panels, the led circuit will not work.
