Solar MOBILE PHONE Charger DIY
11,719
55
9
Published
Introduction: Solar MOBILE PHONE Charger DIY
Easy :
1 . cd case
2  solar battery  x2     (5,5v )
3  usb cable
Step 1:
put batteries in to cd case and add the wires.
Step 2:
thats all :)
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    9 Comments
    That's very easy , thanks for photos too,.. but i think you should put IC 7805 (voltage regulator) to regulate voltage because for many phones' battery 5.5 volts may be high !!
    its really nice project but i think u should add 5v regulator in it.:)
    WOW! Thats definitly nothing you should connect your phone to!
    5.7V is too much for many charging logics and it might ruin your cellphone.
    In addition, many phones require a minimum current supplied, which can not be guaranteed when using direct sunpower.
    Its far better to use a regulated voltage to charge a cellphone, also you should buffer the energy to stabilize the voltage and prevent a permanent on/off when clouds hide the sun.
    This is what i did: Article
    Its a charging controller with LiPo packs, charging over USB or Solar Panel and giving the energy to any USB-Device plugged in when its needed, not only when there is sunlight.
    Although the CD-Case-Panel looks nice, its not recommended to use.
    Greetings
    I think you meant solar panel not battery. It's a neat idea
    Right, sorry for that ;]
    Sounds nice and simple! Where do you get a solar battery? Is it hard to hook the USB to the solar battery?
    Hi
    Polish version of e-bay :
    http://allegro.pl/bateria-sloneczna-solarna-panel-5v-0-8w-i2530579645.html
    It's not hard ;)
    Mobile phones are picky when it comes to the charging voltage. Also, the charging current is definitely bigger than your solar cells. I wouldn't use it on my Iphone. Hint: use them without that plastic lid on. The charging will be shorter.
