Step 4Circuit broach
iImage Information
I'm not sure if I found a good solution for this module of the circuit. I decided to solder all the components together without using a perfboard and without spacing them apart. It does give for a nice tight shape and interesting broach-type look. But it is also a bit confusing to explain in words. Basically you want to follow the circuit diagram and solder little loops to the following three leads so that they can be connected to the other circuit modules: + (plus), - (minus or ground) and the second connection that runs to the motor.
Please take a good look at the circuit diagram and the photos to see how to connect all the components and let me know if I am being unclear and I will try to explain more clearly.
