3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar Ni-cad or Ni-mh battery charger.
hey guys i broke my wrist this instructable took awhile lol. anyway this is a way to charge 2 batteries of your choice using the sun!
every material used as recycled
if you like this instructable please vote for it in the epilog '09 contest
i used my scanner to get this pic.
Step 1Materials:
Materials:
-an old broken solar calculator to take apart for the solar cell.
-a side style 2 cell AA battery holder buy one or get one from an old kit or electronic device that is broken.
-a diode - just an ordinary diode NO LEDS THEY WASTE POWER
-wire
-a volt meter or multimeter
25 comments
Aug 15, 2010. 12:49 PMhsdoofc says:
Thank you for making this so simple! I do have a question though, does a diodes forward voltage drop mean that the amount is lost? and why is this, is it higher drop if the diode can take more voltage or what? the only diodes I could find in my house have a peak inverse voltage of 50v and a forward voltage drop of 1.6v at a forward current of 1amp. thank you
Oct 5, 2011. 6:10 AMdlowther says:
You do lose that Voltage. Most will recommend a schotkey diode because forward voltage loss is only .15 to .45 volts. They can be had for pennies on ebay
Jul 23, 2010. 3:13 PMgolddigger1559 says:
would this circuit have any problem fitting inside a lightbulb with a photo cell and led? and would it have any problem powering the led???
May 20, 2010. 9:09 AMjasongroupindustries says:
Hi, nice job.
I would like to know what is the current rating of the calculator solar panel.
May 24, 2010. 11:43 AMjasongroupindustries says:
Ok, as i test mine and obtain around 20ma with a light source an A/C bulb.
Thanks for the information.
I know now that in sunlight i can have more.
Apr 5, 2010. 1:27 PMmax1zzz says:
 you could use 2 or 3 cells to make charge time 1 day!
Mar 29, 2010. 8:40 PMhansonsux says:
Thing is - a calculator's solar panel produces a miniscule amount of power.  I think it would take months to get one full charge. (self discharge aside)
Sep 27, 2009. 6:05 AMspikeychops says:
OK, this takes a while to charge them, but how to you prevent overcharging and killing the batts?
Sep 30, 2009. 2:44 AMspikeychops says:
Ah right, thanks for that.
May 20, 2009. 3:39 PMnewberrys says:
Will it damage a NiMH battery if you continue to supply power to it after its charged?
May 20, 2009. 8:04 PMnewberrys says:
can it still be used or will it function noticabley less if i use it and recharge it repeatedly?
May 6, 2009. 2:34 AMwcdeich4 says:
Hi. Does the diode protect the solar cell from being damaged as the voltage of battery rises? I'm working on something similar & noticed that it's hard to find diodes w/ forward voltage drops of less than 0.2V, which can be significant. I'm wondering what would happen if we just hooked the solar cell directly to the battery ... ?
May 19, 2009. 4:49 PMhobbles says:
The diode keeps the batteries from discharging into the solar cell when the lights go out.
May 5, 2009. 4:36 PMfang113 says:
what calculator did you buy?
Feb 20, 2009. 8:52 AMPhil B says:
I do agree a more complete drawing of the circuit would be helpful. For a simple way to do it, see my Instrucable on using MS Paint for such things.
http://www.instructables.com/id/Edited_Drawings_saved_as_JPEG/
Feb 20, 2009. 6:04 AMPKM says:
Any chance of some photos of your charger? These images have a slight Googley tang to them, unless you built a beautiful softbox to take photos of your wire in and borrowed your multimeter from Physics 3-202 :P You also didn't mention which way around the diode goes- presumably it's to stop current flowing from the battery through the solar cell. Drawing a circuit diagram (even in MS Paint, as long as you save it as a PNG or GIF not a JPEG) and uploading as an image is much better than drawing an ASCII diagram.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:itsthatsguy
