Step 5Adding the LED tracker
Go to http://www.redrok.com/led3xassm.htm#led3xforsale to purchase one if you want to try this yourself. There are plenty of pictures of how other folks have mounted them at http://www.redrok.com/electron.htm#led3x . I put mine in an empty peanut butter jar and mounted it to a 2 x 4. I attached the 2 x 4 to the side of the unit to get the LED tracker up above the panel to give it an unobstructed view of the sun.
No pun intended? Really? Because it sure looks to me like you absolutely intended to make that pun.
Brian
I have been working on a model for equatorial mount. Mine is for solar concentrators but it is much easier with pv panels. The model is for the norther hemisphere up as far as Calgary.
Rotate the frame at 15 degrees per hour to keep it pointed at the sun.
The actuator can do that. The panels can have adjustment manually for sun elevation with this mount.
