What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
This is pretty much the finished product, and it works well. I had an issue of condensation accumulating inside the peanut butter jar and had to seal it better. The size of the tracker can be made to fit however many panels you need, and there are many ways to configure a tracker like this. I hope this was a helpful, and good luck in your tracker project!
Great project but honestly it could be so much more better looking. Please may I suggest that you find a hippy, artist friend to carve some awesome nature scenes into the wood, faries, suns, moons, stars. etc, then stain it, and you're ready for the solar festivals.
This is a well thought out project! I may have missed it ;but, how does the device return to the morning position after it follows the sun until sunset?Again many thanks for sharing your work!
I like the concept of pointing your solar panels at the sun, and have suggestions for improvement:
1. I would suggest that the wheels be mounted on an A-frame so that struts could be placed from the outside edges of the panels to points tangent to the wheel to provide bracing against strong winds.
2. I find that sun position sensors aren't really necessary for pointing since we already know where the sun will be at any given time of the day. Also, some sun trackers may have difficulties tracking the sun's position on overcast days and may operate erratically on partially sunny days when clouds intermittently block and reveal the sun. A system built around small uProcessor with an on-board clock can be programmed to provide positioning information to your drives, and if you want to get fancy, the sky's the limit for adding sensors, providing web connections, what have you.
For PV panels and the like the sensor method is superior to the clockwork methods because they find the brightest part of the sky. Yes this may not be where the Sun is behind the clouds.
If you measure the power from the panel this other direction will be greater.
Furthermore, the sensor is influenced by other sources of light such as reflective sand and snow adding even more power.
I would think you could use the one tracker to control multiple actuators. you would probably need to set up a relay to accommodate the increased power load when the actuators are on.
If you are having difficulties with the condensation in the peanut butter jar, you could always use a descant. like the little packets that come in shoes, and with dried foods. they usually have little clear balls and are in a paper packet.
Man what a sweet unit! Nice job. The wheels are the perfect rotation device and the actuator would have no problem moving the panels. Very nice. I was wondering if these trackers can be used or set up to control a mirror to continuously reflect the sun at a fixed item?
I have a question about the movement.
How many degrees do the panels move each day?
When it gets dark or with heavy storm clouds it heads toward the Eastern limit switch. If the sun comes back out it resumes tracking.
Duane
Red Rock Energy
redrok.com/led3xassm.htm
Duane
Red Rock Energy
