Solar Power Bucket
42,329
292
39
Posted
Introduction: Solar Power Bucket
Third Prize in the
Solar Contest 2016
This is what I call the Solar power bucket. I wanted a solar battery bank, but many on the market did the have to battery capacity I wanted or could put out 110 volts. If I finally found one it was way too much money. This solved my problem having a 220 Ah battery and a 500-watt 110-volt output. It is very handy to have around, and it charges itself so it is always there and charged for when you need it. It is very easy to make and very cheap costing under 100 dollars. Best of all you can customise it to suit your needs.
Step 1: Parts
These are some of the things you will need
Volt meter, 12-volt plug, and USB adapter sold here: http://www.ebay.com/itm/252435201655?_trksid=p205...
solar charge controller sold here: http://www.ebay.com/itm/151535927837?_trksid=p205...
5 Gallion Bucket
Small solar panel
12-volt lawnmower battery
small dc wire
electrical tape
wire nuts
12 volt to 110-volt inverter ( I modified mine to turn on with a external button )
small switch
110 volt plug extension
You will also need some tools these include
drill and drill bits
wire crimper
wire cutters
Step 2: Drill and Mount Plugs and Panel
Now that we have everything, let's get started. First we need to drill the holes for the plugs. It's alway better to make your holes smaller you can always make them bigger later. For to 110 volt plug you can drill a 3/4 inch hole and use a file to make it square. Push in your plugs and screw on the plastic rings to hold them in tight. Next mark and drill holes for your solar panel. You will also need to drill two holes for your wires to go into your bucket. You can use some silicone to make the holes water tight.
Step 3: Wiring
Next you need to wire everything up. Use some spade crimps to connect to your plugs. After that use the wire nuts to splice all of your positive wires together and do the same for the negitive. It is a good idea to use electrical tape to keep all your wires from turning into a mess. It is a good idea to splice long wires onto the solar panel going to the charger, this makes it easy to take the lid off if you ever have to. Once you are done with that put your battery and inverter in your bucket. If you used the same battery and inverter as I did everything should fit tight and will not slide around. If your battery slides around you could always use some foam to fill in the gaps and hold everything in tight.
Step 4: Your Done
Your done making your Power Bucket. Now take it outside to charge and when you need it, it will be there charged and ready to go. You can use it to power an electric blanket to keep you warm for those cold sports game nights, or when the electric is out to give you light. There are no end to the uses of the Power bucket.
  • Remote Control Contest 2017
  • Design For Kids Challenge
  • Arduino Contest 2017
Questions & Answers
36 Comments
Great idea for proof-of-concept. I ended up making a much more involved unit with a 110Ah 12V UPS battery that set me back ~$180. It weighs about 70 pounds but packs serious storage. My family calls it the MOAB. (Mother Of All Batteries) I use it to pwoer my telescope/electronics when I go to star parties. Normally I wouldn't mess with mower/automotive batteries for this purpose because they are not deep cycle. Using a lawn-mower battery for solar energy storage is like signing up 100m dash sprinter for a marathon. It might technically work, but not optimally. UPS batteries or marine batteries are the way to go. They aren't made to put out wicked amounts of amps in powerful surges. They are made to charge and discharge gradually as they "go the distance." Oh!!, and I need to say, lead acid batteries are very mortal. 3-5 years is not uncommon. Staying away from long periods of time discharged is a good idea too. If this unit fully suites your needs, then great! If not keep on building. The buckets are a great idea, but I'd put some vents in them to limit hydrogen build-up. Also, a pair of lead filled buckets is easier to carry than just one because of balance. You could even securely attach the pair to the ends of a 4 ft wooden closet hanger rod and carry them "milk-maid" style. :-)
I added a 285 watt solar panel to my van with two 6v golf cart batteries to power my Celestron CGE14 telescope. Similar purpose just different choices in the build details. https://www.instructables.com/id/Mobile-Solar-Power-Station/
Any equatorial mount can be a beast to move about, but one made for a 14 inch scope would be a monster. I see from your build that you used a Chrysler minivan to mount your panel on. I thought of doing something like that with the 2003 Chevy Lumina that I take to star parties. Its big enough to transport myself, two others and my 16 inch Orion Dobsonian which is what I use. (Your rig is probably more useful if you do photography) As for panels on the roof, I'd be hard pressed to find a way to keep the panel useful all year round, not just at Star Parties. Right now I still baby it and keep it in the garage so I don't see it gathering much sunlight there. :-) I'd be more interested in building a setup where I could open the trunk of my Nissan LEAF and roll out a stack of thin PV panels on the ground to charge it up, but whenever I do the math, the numbers just don't make any sense. I don't want to have to charge all day just so I can drive 100 minutes at night and then wait over night until I do it all again. It would take me 30 days to cross the US (New York to San Francisco along interestate 80) I sure would get my reading in and would probably have a lot of pleasant conversations with local law enforcement and other curious folk. (but I wouldn't be able to bring my telescope) What I need is an electric van. No manufacturer makes those so I would have to rebuild an ICE one which is no task for the faint hearted or shallow pocketed. :-) Sure would be cool though.
Nice. Portable solar systems are normally really expensive. Also the bucket is a really good idea for a weatherproof housing.
Yes buckets are handy devices for sealing out the elements. I'm not sure this example is the best one, though. Its a bit like putting a square peg in round hole. :-) Now storing 3d printer filament in them with screw top lids and desiccant feels more like putting something round in something round. :-) .....still with enough force..... :-)
You can get square buckets. ;-)
Yea!! I just remembered that I can get 1 gallon ice-cream in more or less square buckets. One more excuse to buy more ice-cream. :-)
awesome!
any specs or guesses for how long to charge the battery or how long you can run what before the battery runs dry?
I have used it before when the electric was out, to power a 40watt light. It lasted about 2 days.
This is just with a using the light for a few minutes every now and then.
