Solar Power Station
Introduction: Solar Power Station
In a similar vein to a number of projects on Instructables I wanted to create a solar powered charging system for the multitude of battery operated gizmos that own. In addition, an aim was to de-clutter the need for multiple wall warts and associated charging leads and accessories.
The outcome is a centrally located station which some effort has been made to make it look like a reasonable piece of furniture in keeping with its location in the centre of the house.
Main Requirements
Recharge Laptops
Recharge Phones (micro USB)
Recharge any USB device with USB charging capability eg ipad/ipod
Large Battery for overnight charging (when sun not shining!)
Easy to use and aesthetically pleasing to look at.
This build was not a cheap one but many of the components I already had or had experimented with on previous projects. This essentially bring them all together in a neat package.
Step 1: Safety Notes
Whilst all the circuits you need to wire are 12VDC and (as such are catagorised as extra low voltage) you are ok to work on a project like this with no electrical license. However I would point out the following notes:
1) A Lead acid battery has a lot of stored energy that can cause problems if you short out the +Positive (Red) and -Negative(Black) terminals. Be very careful when connecting terminals to the battery. It is very easy to accidentally short out the terminals - I know I did it many years ago when working on a car - sudden blue flash and melted battery post Doh!
2) Batteries undergoing charging/discharging can get warm/hot - ensure your project has enough "breathing" space to compensation for this. In this case, given that the maximum output of the Solar Charger is 10Amps and the battery can handle 30Amps initial charge it is unlikely any appreciable heat generation will occur.
3) This project uses a sealed GEL Lead Acid Battery which under normal circumstances should remain sealed. If you use a flooded type battery beware that it produces hydrogen gas during the charging cycle. Ensure that your project is not located in an unventilated area.
Step 2: Skills and Tools Required.
I have tried to make this project achievable by the typical DIY person. The higher your skills and patience are the better the outcome will be. Most of the project is to wire together bought components. This is fairly simple DC circuit wiring. The woodworking skills for the box are straight forward and don't require exotic tools to create.
For the Box:
Saw - handsaw will do
Saw - Jigsaw (for square cut outs in box). A chisel might be an alternative here, but will take a while longer
Drill and set of drill bits
Rulers and pencil for marking out
Paint roller and brush
For the Wiring:
Soldering Iron - only a couple of joints required.
Wire cutter/stripper
Crimper and spade terminals for wire terminals
Terminal screwdriver
Hammer - for cable clips
Step 3: Parts Required - the Battery
I decided to go for a 12VDC 100Ah Lead Acid GEL Battery which is specifically constructed with solar use in mind. This is the single most expensive item and will give 3-4 days of usage if we have a run of cloudy days. Here in Sydney Australia we are blessed with good solar insolation. Your choice of battery and solar panel needs to be matched with your usage which is not difficult to calculate but will be different for each person.
On a more practical note this battery is very heavy and I just about gave myself a hernia moving it about, Anything bigger and it starts to become a 2 man effort.
the spec sheet is here
Step 4: Parts Required - the Solar Panel
This panel was a cast off from a previous project and is plenty big enough to keep the system ticking over nicely. It was bought a few years ago and I think its about ~130-150Watts at full tilt. The unit is mounted on a single story roof facing north (best direction for southern hemisphere). I've used solar cable to wire to a recessed wall plate
Step 5: Parts Required - Solar MPPT Charger
I have used a EP Solar charger and display meter. The package was purchased on E-bay but the website is here:
I choose this controller because:
1) It is a MPPT type to maximise the charge
2) It has a load switching feature which can switch on at dusk or before dawn - I've used this to power a small strip of LED's
3) The charger has an associated display meter showing a number of key parameters.
However there are other controllers with similar specs - so you can make an alternative choice.
Step 6: Parts Required 5VDC USB Power Supplies
Here are 2 small power supplies which are suitable for setting up for USB charging.
One is a switch mode power supply kit from Jaycar. The other is a LM317 based on bough off Ebay. Here are the links.
Both do the job but the Jaycar version is the 'modern way' while the LM317 harks back to the original design which was done in the '70's. Again I had these lying around so decided to use them both. Each power supply could simultaneously charge several devices (@100ma each).
Notes for interest: The switch mode type power supply is great where efficiency and cheaper components are the key however a linear regulator is better where you need very low noise or ripple (for EMI sensitive devices). Both are fine for the job here.
Step 7: Parts Required - Laptop Power Supply
This is a variable voltage power supply for laptops. I bought it a while ago and the closest I can find on the Jaycar website is:
It comes with a range of plugs and should be suitable for most laptops. There are other options out there on the web. Mine is set up for 20VDC and fitted with a plug for my aging ThinkPad.
After construction note: This item seems to get quite warm in use (~40-45DegC) - give it some breathing room!
Step 8: Parts Required - 240VAC Inverter
Yet another part that was bought some time ago and has been previously experimented with. At 300W its not big enough to run a many household appliances but it is good enough to run smaller items such as a TV. Here in Sydney we experience a few power outages each year (due to thunderstorms hitting the overground powerlines). Having a small semi portable (the box has castors) 240V AC supply should be useful in these times. The only house in the street with lights still on!
Here is the link:
NOTE: I have not earthed this inverter and so it should only be used with double insulated devices (devices with 2 pins on the plug).
Step 9: Parts Required - Wall Plates and 12VDC Power Connector.
The wall plates give a professional appearance and the 12VDC "Cigarette" power connector are shown in the photo above.
The 4 way plate is a std wall plate for keystone inserts, the inserts themselves are for the USB sockets (not shown on the photo) are these:
The brush wall plates (2 required - one for back and one for the lid of the box):
The 12VDC socket is:
Step 10: Parts Required - Miscellaneaous
Fuse Box - please fuse all your circuits - a 12V battery can provide a real punch of current that can easily damage equipment.
In-line fuses - used to fuse the main battery to inverter lead and the battery to solar charger lines
There is no reason why I used different leads - its just what I had in the garage at the time.
White LED strip
I had a length left over from a 5M reel bought on E-Bay - it had a self adhesive backing.
Plastic Boxes for internal storage
These 2 boxes came from Howards Storage World - Cadi stackable organising basket large PLF024.
Miscellaneous Parts
1) Wood Glue and Screws for Box
2) Wire Black and Red for DC circuits - I used 15A automotive except for the Battery to Inverter which I used the cable that came delivered with the Inverter (30Amp I think)
3) Spade terminals
4) Cable clips
5) USB cables - to be cut off and used inside the box
6) 25 x 25mm Aluminium Angle - for the basket shelf supports - this is a bit of an afterthought and if I made another box I'd just use wooden battens before painting
Step 11: The Box - Basic Construction
My apologies I did not take any photographs of the basic construction of the box. Hopefully the photographs are enough to guide you into constructing your box. To make the box construction easy I used pine boarding from my local hardware store (sold for shelving primarily) . I utilised the full 405mm width and therefore minimised the number of saw cuts I had to make.
The basic dimensions are:
Nominal Dimensions (dimensions including castors skirting and lid) 740mm Wide 415mm Deep 395mm High
Do not use the nominal dimensions for construction they are only for information to assist you to see if it fits in where you propose to locate the Power Station.
Box Internal: 665mm long x 345mm wide 405mm high (width of the board)
Lid 735mm Long x 405mm Wide x19mm thick (thickness of pine board used)
The size of the box is dictated to a certain extent by the largest item contained within (ie the Battery in this case). If you decide to size you own box I urge you to ensure you have enough space - once you start assembling projects like this if you are tight for space it makes things quite frustrating and can make it hard to maintain or improve. In this case its good to "Go Large".
Pieces required to make the box:
Lid (1) 735mm x 405mm
Front and back (2) 700mm x 405mm
Sides (2) 345mm x 405mm
Base 700mm x 383mm (the base requires a cut along the long side of the board to reduce the 405 width to 383)
After cutting the parts were glued and screwed together. 3 screws down each corner. Leave the box overnight for the glue to cure fully
4 castors fitted to base - as an assembly the finished product is heavy. You will regret not fitting them if you decide to leave them out!
Fit the hinges then remove the lid in preparation for painting and finishing
Step 12: Box - Ancilliary Construction Details
Batten for battery
Add 3 short strips of wood at the left had side of the interior of the box. This is to ensure that the battery will have an air gap all around it. The batten is about 5mm thick.
Batten for LED Strip
Fitted a length of pine molding for the LED Strip
Step 13: Box - Preparation for Painting
I decided to paint my box - I filled in the holes with woodwork filler then sanded down. I fitted the already primed skirting after sanding down.
This finishes off the base of the box and makes the box look like a small storage or blanket box. I fitted the skirting using panel pins and wood glue. The Left hand side requires a cut in the skirting to accommodate the 240V inverter
Step 14: Box - Priming/Undercoating
I used a combined sealer, primer and undercoat. Only 1 coat required. The box is painted inside and outside.
Step 15: Box - Final Finish
I had some wall paint left over from an old decorating project. Slightly off white or should I say "Hog Bristle" as it said on the can.
2 coats required.
To improve the look of the finished Power Station, put a coat of paint on the brilliant white face plates. Simply rub the faceplate with some fine sandpaper to provide a key for the paint.
Note for future...
I have plans to add some finishing touches to the outside of the box. Watch this space - my artistic capabilities are very limited so if the idea doesn't look good it will get painted over!
Step 16: Fit Out - the Battery
Fit the battery into its location in the left hand side of the box. Boy is this sucker heavy!
Note the air gap all around the battery sides.
Step 17: Assembly - LED Strip
Attach the LED strip onto the batten. The LED's are facing upwards so that the light 'washes' the wall behind the power station. Insert a 2 wire cable through a small hole in the box. Solder off the +VE and -VE onto the LED strip. (The LED strip should show which is -VE and +VE).
Step 18: Assembly - Fit the Rear Wall Plates and 12VDC Socket
Fit both the brush wall plate, the 4 way keystone wall plate and the 12VDC socket
Step 19: Assembly - Fit the 240V Inverter
The cutout in the right hand side end fits snugly around the end of the inverter. Slide the inverter into position then screw to the base. 2 screws at the back are enough.
Step 20: Assembly - Fit 5V USB Power Supplies
Fit the 5VDC power supplies that will provide power to charge up all your USB devices. I used spare computer stand off's screwed directly to the base of the box.
Step 21: Assembly - Fit the Solar Charger
Fit the charger to the back side of the inside of the Power Station box. I also terminated the LED strip at this stage. It connects to the load terminals on the right hand side of the solar charger.
Step 22: Assembly - Fit the Fuse Box
Fit the fuse box in a convenient location. We will be fusing each of the 4 circuits individually.
1) For 5V Power supply 1
2) For 5V Power supply 2
3) For Laptop power supply
4) for 12VDC Socket
Step 23: Assembly - Fit the Laptop Power Supply
This cannot be fixed in position so I just placed cable clips on the input and output leads. The output lead will go through the brush wall plate on the power station lid.
Step 24: Assembly - Complete the 12VDC Wiring
Start wiring up the components.
For the main battery to Charger and Battery to Power supply I used inline fuses like this:
Use red for the positive and black for the negative. Keep the routing as tidy as you can and use cable clips to help in this regard.
Step 25: Assembly - Wire From Solar Supply to Power Station
Using around a meter of solar cable to wire from the recessed socket to the right hand terminals of the solar charger. Pass the cables through the brush wall plate in the rear of the box. The spare cable stores neatly underneath the box allowing the box to be placed about 50mm from the wall. The cables from the battery to the solar charger can be done now also. These terminate to the centre connections on the solar charger. Leave the fuse out of the circuit at this stage.
Step 26: Interim Test
Temporarily (and one by one) add a fuse into the circuit and test and set the 5VDC for the USB chargers. There is a potentiometer on each circuit board to adjust the voltage. Remove the fuses and continue. This process should have been completed on the bench but it is a good idea to test again.
Also take the opportunity to test the laptop power supply the Cigarette12VDC socket and the 240V Inverter.
Step 27: Assembly - Wire the USB Leads
Make sure you get this step correct ie the polarity of the USB wires) - I do not want you to damage your phones/ipods etc!
Take a couple of unused USB cables (I'm sure you have some somewhere at home!) and cut the cable approx 150mm long.
Strip the outer cable back and expose the wires. Cut off the green and white - these are the data wires and are not required for charging. Terminate the red and black wires into corresponding terminals on the 5V power supplies. In my Power Station I wired one of the 5V supplies to a multi-headed lead I bought off e-bay and the other to 2 USB sockets on the back of the box. The multi-headed cable is connected to a USB extention cable (with a female type A USB socket on - see photo)
ebay link:
I have left 2 of the USB's disconnected for the moment.
Further USB charging Notes: It is true that these days may devices use digital recognition to allow higher charging currents, however in this case the charging is essentially 'dumb' and each device should default to 100mA to your device. This means it may charge more slowly then when it is connected to its dedicated charger or a computer. I do not find this a problem however - its just good to be aware of it.
Seee the Wiki here for more information and your further education!
Step 28: Assembly - Fit the Box Lid Parts
Fit the brush wall plate and the solar charger meter to the lid. Refit the lid using the hinges. Connect the meter to the charger with the supplied cable.
Step 29: Assembly - Shelf Brackets
Towards the end of the assembly I decided to fit a couple of plastic trays. The idea is that you will have loads of USB leads, wall warts, instruction manuals - basically loads of paraphernalia that needs a home and a location you can go to without searching the whole house!
I fitted a couple of aluminum 25x25mm angle to the right hand side of the box. They are located 170mm down from the top of the box. This is to suit 2 of the plastic trays from Howard Storage World. - if you can not get these I'm sure you can find an alternative.
Step 30: Power Up - Insert Fuses
Reinstall the fuses one by one and check each is operating as you would expect.
I used a 10A fuse for the solar charger and 30A for the 240V inverter
I used 5A for each of the 5V DC power supplies and 10A for the Cigarette 12VDC socket and the Laptop Charger
Step 31: Finished?
I hope you enjoyed viewing my 1st Instructable. Comments welcomed.
The charger has been programmed (via the meter buttons) for the load (LED strip) to illuminate for 3 Hours after dusk and 3 Hours in the morning before dawn. The controller needs no adjustment for this as it continually 'learns' when dawn and dusk is by monitoring the solar panel voltage - I like this feature.
Ideas to improve?
how did your build go?
Comments welcomed.
Step 32: EP-Solar Remote Display Tracer-RN
Here is an update regarding the EP Solar remote display.
Note regarding the display of State of Charge SOC
I noticed that the display would show 100% when the sun was shining then would drop ~20% when the sun went behind a cloud however no charge was being drawn. I e-mailed the manufacturer with the following question.
"Dear Sirs
I have installed a Tracer 1210RN and MeTer system and have a question over the SOC readings. While the sun is shining the MeTer charges the battery to 100% no problem. Later in the afternoon (when no load is being drawn from the battery) the SOC drops rapidly to ~60%. I have checked the battery voltage (12V GEL type) and it still indicate 12.76 volts which suggests the 'real' SOC is about 85-90%. It seems as though the Meter is using the higher charging voltage as the 100% figure rather than 12.85V which is what it should be for this type of battery. Can you please comment."
To their credit they replied with an spreadsheet attachment which I have attached here. The e-mail was as follows:
First, the determining of battery capacity is according its voltage.
It shoulds show 100% on the meter display when voltage is above 13.6V.
So it showed 50% on the meter display because its voltage was 12.8V.
And the detailed in the attachment.
I'm not sure what to make of this information. The meter performs as per the attached algorithm but I don't understand why the meter seems to measure the charging voltage rather than the open circuit voltage? Perhaps the internal circuitry in the meter can not do this?
Anyway this is beyond my expertise to take this any further. Are there any battery charging experts out there?
Step 33: Making the Box More Artistic
With the help of my sister and a pack of Martha Stewart stencils we have added a touch of colour and uniquness to the bland beige box!
Martha Stewart Ferns Stencil
using a foam roller and a mixture of acylic paints (3 shades of green and one of brown) - I got these materials from a local artist supply shop. The techniques is to place layers of ferns with a first dark layer for the background. This is followed by a slightly lighter colour then a final light layer for the ferns in the foreground.
Have fun!
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    Hey thanks for adding the comment about the SOC readings from this charge controller. I have been unhappy with the readings as well and think it's quite dumb that they have it set for the charging voltages instead of open circuit voltages and with setting it up like that they shouldn't have even shown a SOC in the user interface. Or they could have a separate battery capacity % and current charging status %.
    see my comment above
    Hi JordanC8 - I think its confusing - however I've got used to doing a translation my head. In the evening I regularly draw down the battery to ~45% but in reality I know this is still about 75%! Ah well.
    Also, can you please send me the attachment to view.
    Love this idea, I would like an answer to the same question as the previous commenter as to how it is holding up. Trying to use less and less resources that I have to directly pay for.
    Hi I'm back on Lord Howe Island so very little internet coverage and no mobile phones (yay)! So sorry for late reply.
    The system is holding up very well. I've monitored the voltages and everything seems good despite the last few months being winter ones here in Sydney. The only issue I have found is with the remote Meter for the solar charger. I have added a step near the end of the intructable to go through the issue.
    I've also thought of adding a connection for my AA and AAA charger I might add a step about that too when I come around to completing it.
    I've learned a lot from your instructable. Looks very clean and well organized. I'm planning on building one for myoff-grid
    remote cabin. Do you have a circuit diagram for this? I'm a total
    beginner so if you could please post or send it to me I would be greatly
    Also how is the EP Solar charger holding up after all these months? I'm torn between this and an Eco-worthy charge controller. What parameters does the remote display? I heard that the battery status doesn't work at all. Is this true. I really appreciate any reply. Thank you.
    I too have a concern regarding the EP solar remote indicator. I have added a step (32) at the end of the instructable that you may find useful.
    Really, really nice! I wish I had the confidence to build something like this... But the many meters, wires and plugs still intimidate me a bit. I think I'll start with a smaller project. But still - I read your whole instructable and think it's excellent, logical and for people with a little more techie sense very doable.
    Thanks for the comment Sabine - as you suggest, maybe you could try with a simple system to start with then build up confidence & expereince from there.
