Supplies:
Solar panels
Charge controller
Battery charger
2 AWG cable
At least one 12 Volt marine deep cycle battery
Mechanical lugs
1 power inverter
1 Rubbermaid tote or other container
1 battery charger
Tools:
Cable cutters
Red electrical tape
Screwdriver
Drill
Crescent Wrench
Gather supplies and lets get started.
Remove these ads by
Signing UpStep 1: Preparing the batteries.
While the batteries are charging, you can set up the solar panels and get them wired up and ready to go.
Visit Our Store »
Go Pro Today »
5-20 Watt panels
2000 Watt sine wave inverter
200Ah Trojan battery
10 Amp DC breaker
and ah whole lot of odds and ends.
Your I'ble inspired me to do it.
The inverter is a Xantrex.
Thanks!
1. The solar panels need full sun with no shading what so ever, the efficancy of the PV panels is significantly reduced if they are even partly shaded.
2. Avoid any battery that has a CCA rating. The CCA stands for cold cranking amps and indicates a starting battery. Starting batteries should only be discharged to 80% capacity or they will be perminantly damaged. A Marine deep cycle battery with out a CCA rating will be able to be discharged to 50% capacity where as Golf Cart batteries can be brought down to 20% with out perminant damage. The down side to golf cart batteries is that they are 6 volt and would need to be wired in series and in parrallel.
3. One will want to vent the battery box to the outside. several people have spoke about hydrogen. Granted I have never heard of a battery box exploding, I have witnessed a battery explode in the battery room when it was charging. It is also a good idea to keep some baking soda close hand to nutralize any potential spills while topping off the batteries water.
An example of outdoor housing for batteries could combine a surrounding structure that is well insulated. It could incorporate passive solar heat by exposing a southern wall to radiant heat via a glass panel.
It could employ a venting system that makes use of the convective heat flow: a louvered opening near the bottom, and another louvered opening near the top of the structure, for instance - where the bottom opening would face the direction that absorbs the most heat: the south.
Such openings could be closed off in winter in order to contain the radiant heat that is absorbed through the southern window (but, SOME ventilation MUST be present in order to prevent the accumulation of hydrogen gases that emanate from the batteries).
My own solution was to buy AGM (aggregate glass mat) batteries that are maintenance-free and do NOT release any gases. I keep my battery bank INDOORS, and safely so because of the nature of the batteries. I got mine on sale 4 years ago, but usually, AGM's are much more expensive than regular wet-cell batteries.
If I had to replace my battery bank at this time, I would probably NOT buy AGMs again. I would buy a number of wet-cell batteries, (compare the brand Trojan), and I would build an add-on to my house, well isolated by a firewall, to house the new battery bank. I would also, at that time, put the add-on to additional use as a garage, fire-wood storage, workshop, etc. I would move my solar panels from their present location on the roof of my house to the roof of the add-on (which, of course, would have a south-facing roof slope).
If I were to seek a building permit for my plans, it would most probably result in a code requirement to have a distance between the 'battery building' and the house. If I chose to actually get and satisfy such an intrusion to my personal choice, I would most probably seek to use the 'distance' space as a walkway, or try to put it to some other good use.
The only reason why I WOULD deal with a permit would be because I would consider my property as something I will eventually sell off and move on, thereby having to satisfy inspection by the new owner's government watchdogs.
I am not planning to sell my place, so it is more likely that it will be left behind as leftovers of my life - kind of like the lifeless physical body that will also be a 'remains' - unless, of course, a being appears in my presence who loves the place as much as I do and wants to keep caring for it. I mean the place, NOT the body. The best that can happen to IT is some coyotes or crows finding an easy meal.
So, let's look at 'what is' and chuckle a little bit about it :)
And keep finding options. Rarely is there EVER a problem that has only TWO choices for solutions. We're just conditioned to not LOOK for the other choices :)
If you lease a solar energy system from a company that offers a solar lease they'll actually handle all of the maintenance and cleaning for you. If you build 'em or buy 'em outright, you'll likely need to clean them once a year yourself.
Have u ever completely drained them?
Showing up how to wire it up in step 3 in parallel is very helpful.
I dont understand what all the complaints are in this one in the comments field. Having a big 12V battery connected in parallel is more useful and easier to do than using odd voltages like 24V.
Im not worried about ventalation either on the hydrogen gas building up in the container. I myself have kept batteries in a container and it is perfectly FINE. Ill just head over to mine and light a match. Oh hey, Im still alive.
Keep on writing up good stuff like this!
http://www.tscrenewableenergy.com/tsc_t3_s1_p2.php
2) After having this set up for a while now I can safely say the panel is very much undersized for the set up. It is taking about a week to recharge sometimes. And now that winter is coming where I'm at it is taking over 2 weeks some times (if not longer). So, 60 Watt solar panels are not good enough for continual use of this set up. But, since my original plan was having this as emergency power, I'm still pleased with the results.
3) 50 kilowatts is pretty high. 50 kilowatt hours = 50000 watt hours. 50000/12=4166.37 Amp hours. 4166.37 Amp hours/125 Amp hours = 33.33 Batteries. So, about 34 batteries of this size to run the 50 kilowatts.
Here is a pretty good website about electric solar panel systems...
http://www.solar4power.com/
Hope that helps.
this is the one im looking to buy
http://store.altenergystore.com/Inverters/Off-Grid-No-Utility-Needs-Batteries/1000-to-1999-Watts/Go-Power-1500W-SW1500-12-12V-Inverter/p584/
http://www.roadtripamerica.com/dashboarding/Power-Inverters.htm
Optima Battery 9051-160: Battery, YellowTop, 12 V, Deep Cycle
Link:
http://www.amazon.com/exec/obidos/tg/detail/-/B0006I2QYY/qid=1100621096/sr=1-1/ref=sr_1_1?v=glance&s=hi
It runs for about 245 dollars. And it says on a website that it has a 1125 amp capacity. Is that 1125 amp/hours?
I want to know so I can compare it to Mr Chickens batteries.
Thanks
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_84580_-1
