Step 7Some final thoughts.
I originally tested out a single battery and was able to run a lamp and my laptop for about 5 hours before I finally shut it off. The good thing about this inverter is it will shut off automatically if the voltage drops too low to prevent depleting the batteries. I'm pretty confident that with the three batteries I will be able to power larger items for an extended period of time.
Also, this is a pretty expensive set up, about $650. My costs (with out tax or shipping charges) and where I got things.
Solar panels $250 (used from craigslist)
Marine batteries $240 (for 3 from Walmart)
2 AWG Cable $5 (for about 2 feet from Lowe's)
Lugs $8 (for 8 from Lowe's)
1200 W inverter $130 (Amazon.com)
I had the rubbermaid container, battery charger, and the charge controller came with the solar panels. I don't think it unrealistic to spend around $700 or so, possibly more depending on how you set your system up.
Depending on how this works I will most likely upgrade to some better solar panels, increase the solar panel array size, and get some more batteries.
If anything is unclear please post comments/questions and I will be more than happy to update.
An example of outdoor housing for batteries could combine a surrounding structure that is well insulated. It could incorporate passive solar heat by exposing a southern wall to radiant heat via a glass panel.
It could employ a venting system that makes use of the convective heat flow: a louvered opening near the bottom, and another louvered opening near the top of the structure, for instance - where the bottom opening would face the direction that absorbs the most heat: the south.
Such openings could be closed off in winter in order to contain the radiant heat that is absorbed through the southern window (but, SOME ventilation MUST be present in order to prevent the accumulation of hydrogen gases that emanate from the batteries).
My own solution was to buy AGM (aggregate glass mat) batteries that are maintenance-free and do NOT release any gases. I keep my battery bank INDOORS, and safely so because of the nature of the batteries. I got mine on sale 4 years ago, but usually, AGM's are much more expensive than regular wet-cell batteries.
If I had to replace my battery bank at this time, I would probably NOT buy AGMs again. I would buy a number of wet-cell batteries, (compare the brand Trojan), and I would build an add-on to my house, well isolated by a firewall, to house the new battery bank. I would also, at that time, put the add-on to additional use as a garage, fire-wood storage, workshop, etc. I would move my solar panels from their present location on the roof of my house to the roof of the add-on (which, of course, would have a south-facing roof slope).
If I were to seek a building permit for my plans, it would most probably result in a code requirement to have a distance between the 'battery building' and the house. If I chose to actually get and satisfy such an intrusion to my personal choice, I would most probably seek to use the 'distance' space as a walkway, or try to put it to some other good use.
The only reason why I WOULD deal with a permit would be because I would consider my property as something I will eventually sell off and move on, thereby having to satisfy inspection by the new owner's government watchdogs.
I am not planning to sell my place, so it is more likely that it will be left behind as leftovers of my life - kind of like the lifeless physical body that will also be a 'remains' - unless, of course, a being appears in my presence who loves the place as much as I do and wants to keep caring for it. I mean the place, NOT the body. The best that can happen to IT is some coyotes or crows finding an easy meal.
So, let's look at 'what is' and chuckle a little bit about it :)
And keep finding options. Rarely is there EVER a problem that has only TWO choices for solutions. We're just conditioned to not LOOK for the other choices :)
