Air-Lift Irrigation
2,006
28
Posted
Introduction: Air-Lift Irrigation
This is an instructable for making a solar powered air-lift irrigation for the vertical or hanging garden.
Step 1: Items
  1. 2.40v solar panel
  2. 2 meter electric cable
  3. Battery powered air pump
  4. Aquarium air tube
  5. Air valve
  6. 3-way air connector
Tools
Scissor
Step 2: The Connections
  1. Firstly, I connect the air tube with the 3-way connector.
  2. One the air tube, I connect it with the air valve (make sure to connect correctly)
  3. The same tube, I connect it with the air pump.
  4. The next tube, I connect it with the water reservoir.
Step 3: The Test
    1. When the sunlight is sufficient, I switch on the air pump.
    2. The water from the reservoir flow to the 3-way connector. Because there is a air valve installed, the water is prohibit to flow into the air pump.
    3. The generated air then push the water up (air-lift) to the top planter.
    Step 4: The Irrigation
      1. The water flow nicely at the top planter.
      2. Soon, the water will flow back into the reservoir.
      3. The cycle continue.
      Step 5: The Setup
      This is how I arrange the solar powered air-lift irrigation for the vertical garden.
      Happy gardening!
      Please, don't forget to vote for me.
        • Spotless Contest
          Spotless Contest
        • Pocket-Sized Contest
        • Microcontroller Contest
