Remove these ads by
Signing UpStep 1Materials/Tools
Solar Cell (I used a 6v 50mA one)
SKU: 277-1205
Project Box (I used a 5x2.5x2 and it fits perfectly but any small enclosed box that you can cut holes into will do fine)
SKU: 270-1803
12VDC Car Power Outlet Socket
SKU: 270-1556
Vecro (or your adhesive of choice)
SKU: 64-2345
You will also need a soldering iron (15 watt. SKU: 64-2051B), solder (62/36/2. SKU: 64-013), and something to cut 2 holes in the project box (I didn't have anything available designed specifically to cut holes, but I just used my CRKT knife and it worked fine)
Example:
If you have twenty-four instead of twelve watts run to it, it will output at twenty-four, not twelve.
knuxz the PORT is just a contact, as you stated. there is nothing else there.
lloydrmc, you are right in the charger, but technically Knuxz is also right, as he specified the PORT, not the CHARGER. the charger would be expecting 12V at like 10 Watts (i am not sure on the wattage, if i am wrong, i appologize) the charger probably has a transformer in it set to about 2.4:1, so if 6 volts go in, you will not have the 5V the phone is expecting, or what every the phone wants. i am going off current phones which normally go straight from USB at 5V.
Look - this would make a LOT more sense with more/better solar cells, and some NiCD or NiMH batteries to store the juice. Set it up so you have nor more than C/10 or maybe C/5 at about the correct voltage, in optimum sun conditions, and you will be fine.
"C" is the capacity of the battery. So, with 3000mAh AA batteries (which are available cheap as dirt on ebay), you set it up so you have no more than 300 to maybe 600 mA output from the solar cells.
You'll note that the specified solar cell has a current rating much lower than that. No problem, except that it would take proportionately longer to charge any given battery. It would also help to orient the solar cell properly, at the correct heading and angle (rather than have it just sit flat on top of the box.
I'm pretty sure someone has a solar-assisted minty-boost project on Instructables..
i looked at your comment, and yeah, you could go for a battery bank, but that would as you said, take a while to charge. The other thing is, i think i was suggesting more along the lines of smoothing the charge, or maybe a quick emergency charge, like 5-10% of a cell phone batt to allow for a call to a tow truck... i am not 100% sure, as it has been over a year and a half since i have looked at that.
1) what type of capacitor should be used for this circuit? I have tried looking into it at radioshack.com but couldnt get myself up to speed enough to understand what uF meant in relation to what is needed/required
2) I was thinking about adding in a AA batter "box" to hold two rechargeable batteries, where would I need to splice that in to this circuit and would the one panel be enough to charge this. Ideally I would like to use the solar panel to charge the batteries and use the batteries to charge the device. To go along with this, would I need to install other items (ie blocking diodes, voltage regulators, etc)?
If anyone can help I would appreciate it, thank you!
Of course the sun has to be out rofl...
It will work for other phones
You must use a 7805 voltage regulator, which brings the voltage down to5 volts because it might be too much or too little voltage from thesolar cell.
2nd
You might overcharge the cell phone and power surges will definitely fryit; put in capacitors.
3rd
Radio shack solar cells are frickin expensive.
2nd the phone takes care of that, capacitors won't help, and where exactly are the power surges coming from? Just exactly how clean do you think car electrical systems (which the car charger is designed for) are?
3rd Expensive compared to what? What other store is everywhere that has them available? Can you really get something like that, in single quantity, elsewhere for all that much less?
