At the core is a standard off-the-shelf keychain digital picture frame. It is mounted in a fancy enclosure, in this case a flower that is modeled after a chrysanthemum. On top of that, a solar cell has been added so that the picture frame will run indefinitely when placed in a sunny window! Or, you can simply plug it into any USB port and let it run from there.
It can be made using basic tools, including an X-acto knife, soldering iron, wire strippers, and a drill.
Remove these ads by
Signing UpStep 1Materials and Tools
MATERIALS
1.5" Digital picture frame - DealExtreme.com
5V, 160mA Solar Panel - DealExtreme.com (or equivalent)
Small flower pot
Some pieces of craft foam - available at any craft store
A mini USB cable - online or in stores
A 0.3V Germanium Diode - to protect the solar panel
Some bits of wire
A chunk of wood, between 0.5 and 1" thick
Some hard plastic drinking straws (or equivalent)
White glue
TOOLS
A Soldering Iron
A Glue Gun
A Scroll Saw or Band Saw (optional)
A Drill Press (or a hand drill, in a pinch)
Scissors
An X-Acto knife with a fresh blade
A computer and printer
Wire cutters/strippers
Thanks for any help I can get
Peter
Thanks,
Peter
Had you thought of making a USB plug in the base of the pot or concealed under some fake dirt? That way you could move it away from the computer to a window shelf and ditch the trailing wire - suppose you would need a donor USB cable to take a plug from.
Very nice idea.
