3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar Powered Digital Picture Frame
Step 10Add Fake Dirt
Add Fake Dirt
  • last photo ←
The flower pot won't look real without some fake dirt. Well, I suppose you could use real dirt if you wanted to...
Take a piece of black craft foam about 2.5 times the surface area of the wood "flower bed." Lay it on a cutting mat, and with the aid of a ruler cut it into strips about 2mm wide. You should have a dozen or more foam "strings."
Now for the long, annoying part. Cut each string into 2x2mm pieces. Make a few hundred. Fill a small container with them. Your hands will hurt. But they look good, so keep going.
With all the pieces cut up, lay a thick layer of white glue on the surface of the wood flower bed. Crumble the foam pieces onto the glue, and spread them out so they're even. Press them down into the glue, so that as many as possible get stuck down.
And that's it! The assembly is done when the glue is dry - now it's time to load up some pictures.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
