Step 11Load Pictures into the Digital Picture Frame
Plug the flower pot into your computer (sorry, PC only). Nothing will happen at first. Hit the "menu" button on the digital picture frame, and select "USB Connect," then "Yes." The picture frame will show up as an external device in windows, with the option to run a program called "DPFMate." Run it.
A single window will pop up. In the top left is a browsable directory of your computer, in the bottom left is a preview pane for basic edits. Another pane on the right shows the pictures currently loaded into the picture frame.
I deleted the three pre-loaded pictures, pretty as they were.
Browse to the first picture you'd like to load up. It will appear in the lower left window, with dotted lines showing what part of the picture will appear on the display. But wait! To compensate for the fact that we rotated the picture frame onto its side, you will need to rotate each picture. Hit the "Rotate Left" button on the side. Then, drag the dotted lines to center the image you wish to display. Hit "Add" and the picture will be added to the pane on the right.
Do this for every picture. This little frame has room for an amazing 138 pictures! Once you are finished, hit the "Download" button. This will load all the pictures onto the digital picture frame. When the download is complete, hit "Exit." Then, from the sidebar, choose "Safely remove hardware." You may now leave the frame plugged in to run from USB power, or unplug it to run from solar and/or its own internal battery.
Oh! One other thing. The digital frame I used has an option to turn off the automatic power-off feature. I recommend doing this, so that the pictures continuously display all day. After all, with enough light, the battery will never drain!
And there you have it - a solar powered digital picture frame disguised as a flower. It makes a great gift and looks super displayed in a sunny window or next to your computer.
Add Comment
