3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar Powered Digital Picture Frame
Step 3Cut Out the Frame
Cut Out the Frame
  • last photo ←
With your frame design complete, you can print it out on your printer on regular paper.
You may have noticed that the border of the cutout for the digital frame gets awfully close or even overlaps the edge of the petal design. That's OK! With a pen, draw a new path for the petal around the cutout, so that you have at least 3mm spacing. This will be hidden (or not noticeable) when you stack the layers on top of each other. (You may also do this ahead of time in the graphics program.)
Select a piece of craft foam in the colour you'd like, and tape the pattern onto it. It should lie as flat as possible on the foam. With the X-Acto knife, cut along the lines of the pattern and through the foam. I found it easier to start by cutting out the holes in the middle of the petals. Once the holes are cut, you can wrap another piece of tape around the hole to keep the pattern from shifting.
The petals themselves are harder to cut. Start at the inside and cut towards the tips. Be careful and patient, the paper may want to snag. Once the flower petal is cut out, gently test it to see if it will come out on its own. If it doesn't, don't tear it out! Use the knife to gently cut any corners that don't meet up.
Repeat for all of the petal patterns.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
