Step 4Glue the Frame
Start with the first and second layers - the smallest patterns. Stack them up so that the cutout for the display lines up, and the petals are staggered. When you're satisfied with the alignment, lift off the top layer and apply some glue to the underside. Stick it back down exactly as it was before. Wait a little while for the glue to dry, to make handling easier.
Lay the digital frame on its back, and set the petal pattern that fits around the bezel in place. Dry-fit the top two layers on top, and arrange alignment for a good fit. You may have to remove the bezel-layer petal and place it upside down, depending on the top two layers. Again, make sure the display is lined up properly and that the petals are staggered. When you're satisfied, glue the top two layers in place onto the bezel layer. Try not to get glue on the digital frame itself, in case you need to remove it later.
Once the bezel layer is dry, flip the flower face down and line up the next largest body layer. As before, line everything up so the petals are properly spaced and staggered. Glue this layer and the next in place.
Now you can glue the back pieces on. Take one of the back pieces, and as before, glue it in place around the digital frame. It's OK if part of the USB connector is starting to be covered up - this will be cut out later.
Stack up as many of the rectangular spacers as are necessary to completely cover the thickness of the digital frame. I needed three. Glue them in place and set aside the flower for now.
Add Comment
