3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar Powered Digital Picture Frame
Step 5Modify the USB Cable
The digital picture frame probably came with a little mini-USB to regular-USB adapter. You won't need it. Instead, grab a cable that has the same mini USB plug on one end, and a regular USB plug on the other. Most digital cameras will come with a cable like this; look for one online or at electronics stores.
In order to fit the mini-USB end into the tight confines of the flower, you'll need to cut away the plastic body of the plug. Using an X-Acto knife, CAREFULLY cut away the plastic. Be sure not to cut the cable itself, or your finger. Eventually, you should be left with a much smaller metal-shrouded connector with a cable crimped onto it.
You will now need to decide how tall your flower will be. The stem should be a narrow, hollow piece of plastic. I used a reusable drinking straw, since it was lying around and looked nice. You can use whatever you want, but you may need to wrap some green foam around the stem to complete the look. The cable will run through the stem and into the base of the flower pot, where it will be connected to the solar panel.
I decided to use the entire length of the straw. Holding the flower roughly on top of the stem, I estimated how long the cable should be. I added a bit of slack for the cable to make a loop where it enters the straw, and another extra bit where it exits the straw. When you're satisfied with the length, cut the USB cable. Need I remind you to double-check your measurements? No? Good. :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
