Step 6Add the Stem to the Flower
Note the position of the connector on the digital frame, and put two small marks on the rectangular spacers on either side. Using the X-Acto knife, cut the two spacers underneath the top spacer, so that a hole is created for the plug to pass through. You may also have to cut down into the first back petal layer. Plug in the connector, and make sure the digital frame isn't squeezed to one side. Everything should fit without being stressed.
Slide the cable into the stem so that the opening of the stem is about midway along the body of the digital frame. Note that the frame will actually be mounted sideways so that we still have access to the buttons on the side. Squeeze a curve into the cable so the stem stays in place. Make sure the stem is in the middle of the flower, and not the frame - then, glue it in place with hot glue. Be sure to hold the stem until the glue has hardened. Put dabs of glue on the case of the digital frame and on the rectangular spacers.
The final back piece is then laid on top of everything. Hold it in place, and make note of where the buttons are on the back of the digital frame - a hole will be cut later. Glue the back piece in place with hot glue, sticking it to the rectangular spacers first, and then moving out to the tips of the petals. The petals will be stretched slightly, so you'll have to hold down each one until the glue dries. Make sure the back piece is firmly glued to the stem as well.
When the glue is hardened, use the X-acto knife to cut a small access hole for the buttons on the back. Start small and enlarge the hole until it's just large enough to fit a finger.
Add Comment
