Solar Powered Night Lights
PrintPrint PDF FacebookFacebook TwitterTwitter Send this to a friendE-mail
by botronics
introSolar Powered Night Lights
Do something useful with your solar powered garden light. Instead of lighting up the garden path at night for that opossium raiding the trash, bring the light into the house. Use it as a solar powered night light.
I mounted two garden lights on the roof with wire extensions of the leds brought into the house. Just the solar cell unit with built-in batteries are on the roof. The led (Light-Emitting-Diode) that makes the light is in the house. The solar lights are mounted on top of a swamp cooler on my roof with the wiring brought through the vent.
Remove these adsRemove these ads by Signing Up.
step 1Mount the solar lights
Use 1 inch PVC tubing to make a holder for the lights. This is what the light holder looks like after construction and mounted on the cooler. But first, go get your saw and start cutting some tubing. The next step will show you how.
To Download the PDF or View All Steps,
Become a Pro Member »
49 comments
1-40 of 49next »
Apr 23, 2010. 12:49 PMjontj2000 says:
I have a solar panel on the  outside of the south wall that goes with a set of solar rocks for a pond. I ran the wire threw the wall and put the lights over the kitchen cabinets for night lights. Free night lightning      t l
Apr 18, 2010. 5:27 PMflying pie says:
im going to camp a i want light in a tent and to charge a ds and phone/ labtop also power a cfl
Jun 6, 2009. 11:37 PMlil27mike27big says:
Let me help you out With the plastic part here is what you need to do first is it on a stick or flat on the ground let me no then i can help you with the prob k (%)
Apr 29, 2009. 8:40 AMdoo da do says:
First solar yard light I have seen with 2 batteries.
Dec 31, 2009. 4:35 PMHycro says:
The solar lights we have that are similar in look to those ones are two-battery setups...
Jun 6, 2009. 11:27 PMlil27mike27big says:
Well i am making one solar yard light and i hooked 3 panels together and hooked all 3 lights up 2 lights to the one light and then now it works great & for the batterys i am using one C.battery.
Dec 31, 2009. 4:37 PMHycro says:
Lol...I was about to say..."Awful big leads on that LED, don't you think it's overkill?" then you said the heat-shrink wasn't shrunk yet...
Dec 31, 2009. 4:33 PMHycro says:
Now up here where I live, where we get colder winters (with ice, snow, all that stuff, though we're getting more rain than snow every year, but still have the icy coldness) it would be advisable to have just the solar cell and the photocell on the rooftop, though as a personal choice I would have the photocell inside, near where I have the night light, so that it would come on when I need it inside, which is usually before it's needed outside.
Jun 29, 2009. 11:03 PMslim_jim says:
Mobile homes? Here in New Mexico, where it is very dry, everybody uses swamp coolers. The extremely low humidity makes them very efficient. Around here, a typical AC unit is called "refrigerated air," and is quite uncommon.
Jul 30, 2009. 8:00 PMianb505 says:
yes jim, new mexico is stupid dry, i'm in albuquerque boing work for a plumbing company. Swamp coolers are 'replacment' air while ac use 'recycled' air. Since swamp coolers are drawing the air from outside, it's a good idea to leasve a window open to alow air to escape. While recycled air comes from inside where it is allready chilled so venting is counterproductive. almost all i've done this week is fix swampcoolers but more and more people a buying into AC.
Jun 6, 2009. 11:54 PMlil27mike27big says:
thats a good idea
May 10, 2008. 7:08 AMomkar_hummer says:
can this be used on a bicycle? what voltage does it gives
Jun 6, 2009. 11:51 PMlil27mike27big says:
yeah i just made me one for my bicycle and for night time or for when your walking in the woods at night time it works very good i hooked 3 panels up 2 lights & to 1 light hook it to the solar panel pop the battery up and now you have 3 in 1
Dec 7, 2007. 12:15 AMalxram says:
If you have a larger house and yard there are so many practical uses for this kind of setup. I'm sure you could hide the solar collectors in many places, and take care of all your night lighting needs. Thanks for this creative and efficient idea!
Mar 25, 2009. 1:00 AMdigitalenigma says:
have you tried spray painting them white or silver to reflect some of the UV rays back out?
Aug 2, 2008. 2:03 AMhcold says:
What's the possibility of keeping the LED with the lamp, and just using fibre optics to transfer the light into the house?
Sep 4, 2008. 5:31 PMslchorne says:
Fibre optics would be far more expensive that a few feet of wire and some solder. you would also need a lens at the end of the fibre to disperse the light again.
Sep 4, 2008. 10:29 PMhcold says:
According to the thing I read (sorry, this was a while ago, so I can't provide the link) they just had the end of the fibre optic in an transperant acrylic end, which had been scratched (can't think of a better word for it) so the light was diffused, rather than a lens.
Jun 6, 2009. 11:46 PMlil27mike27big says:
here is the prob man i bet its the wire If its really long cuz the juice is running that far, so you just need a bigger battery so that it can run in that long wire & last longer to hope that helped you some (%)
Sep 4, 2008. 10:33 PMhcold says:
Depends on the quality of the fibre you're using, doesn't it? And on how far it was going. Also, back to slchorne, you're aboslutely right about the price cost, the site I was just looking t was listing 20-30 British pounds for 2-3 metres of fibre optics, though this was telecoms grade.
Dec 26, 2009. 8:45 PMGrumpyOldGoat says:
Call your local phone company and ask if they have some cut off pieces they will let you have.
The shortest piece I got so far is about 30' .  It has muti pairs, and rubbing alcohol cleans them up nicely.
Jul 11, 2008. 2:18 PMSunny124613 says:
wow pretty impressive
Apr 15, 2008. 9:09 AMdoo da do says:
I wired two of the solar panels together so there would be more miliamps sent to the batteries and the lights seem to last longer with a stronger charge
Apr 15, 2008. 11:26 PMdoo da do says:
parrell, if you use series the voltage would go up and that may be more than the battery should recieve
Apr 10, 2008. 4:40 PMcharleeanna says:
awesome!
Mar 15, 2008. 9:11 AMdoo da do says:
I wired two solar panels from old solar yard lights in parrell and they seem to give the 1.2V battery a longer run time, a few more ma, you may want to give that a try. I do like the light inside part
Feb 14, 2008. 10:28 AMbradleypowell says:
There is a interesting article about using a microcontroller (atTiny11L) as a charge pump to drive LEDs in a flashlight in Nuts & Volts this month. It claims to be very efficient as it doesn't require resistors to do the current limiting. I'll tell you if it works...
Sep 4, 2006. 3:11 PMJack Daniels says:
How many LED's do you think you can run off this Unit and get a good amount of Run time every night?
Dec 22, 2007. 11:28 AMcarpespasm says:
also, those solar lamps often have simple nicad batteries in them, the ones I've had are usually in the range of 800ma. If you added more LEDs to the mix and higher capacity batteries you could add in as much as the solar panel can charge.
1-40 of 49next »
