Solar Powered Phone Charger Dose Not Work See My Other One
310
4
Posted in TechnologyElectronics
Introduction: Solar Powered Phone Charger Dose Not Work See My Other One
have you ever been in the middle of nowhere with no power and your phone dies? well, I have a solution for you...
Step 1: Tools/materals
tools
-soldering iron
-hack saw
-side cutter/ wire cutter( not pictured)
materials
-solder
-wire
-USB charging block
-solar panel (5v+)
Step 2: Open the Charging Block
Use the hack saw to cut open the USB charging block(be careful not to cut the circuit board)
Step 3: Cut the Plug Leads
Use the side cutters to clip the leads off the plugs
Step 4: Get Wire
Step 5: Solder the Leads
solder the wires on the USB leads to the correct colored wires (use heat shrink tubing to keep it all together.)
Step 6: Wire It All Up
Connect the wires to the solar panel and head outside to test
Step 7: Finished
You are all set with your new solar powered phone charger. Take it on a picnic or a hike and charge your phone anywhere
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    3 Comments
    Great, you made the part of my instructable which I have bought.
    Could we also solder a USB extension cable directly to the panel? Or is there an over voltage / over current protection in the plug which you need.?
    I plan a similar instructable to charge 18650 li-ion and a Sony battery.
    What a cool idea! How long does it take to charge your phone?
    a little longer than it would with an outlet
