3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar Powered Robot from TRASH!!!!
Update; My age category for the contest is 13-18 because I am fifteen. :)
Yes, the title explains it pretty well. In this Instructable I will show you step by step how to construct a light sensitive, solar powered, robot. All you need is some parts that can easily be found in the trash or in your backyard. I built mine totally from trash.
Step 1Bits and Pieces
Bits and Pieces
Parts...
2- 1.5 volt motors
1- AAA battery pack that holds 2 batteries
1- On/Off switch
1- Old solar powered garden light
Random bits of wire
zip ties
And something to use as the chassis for your robot, I used some bits of Erector Set parts, but almost anything can be used.
Tools...
Needle nose pliers
Wire stripper
Screwdriver
Scissors or wire cutters
A vice grip (optional)
Magnifying glass (optional)
Soldering iron and solder (not optional)
Glue gun and glue
44 comments
1-40 of 44next »
Apr 8, 2012. 7:21 PMegil samaniego says:
where can i get or how can i made the control circuit?
Feb 22, 2012. 6:24 PMTIoistprime says:
you could use some of the ideas of the beetlebot to make this robot automatically void things.
Feb 3, 2012. 10:44 AMvadipp says:
Where are such solar-powered lights used usually? In the yard? They charge during the day, and then shine at night? I've never seen such stuff.
Feb 3, 2012. 9:23 PMvadipp says:
Yeah, I'm from Russia. Thanks for the info and the i'ble!
Oct 15, 2011. 8:32 AMkamid99 says:
Could I put sensors on the front to make it Solar powered and sensored? I'm in 7th grade so would this be too hard for me?
Nov 24, 2011. 6:35 AMsmelly210 says:
if u did it would not be from trash
Nov 13, 2008. 7:56 AMkamid99 says:
Do you think that this will make me win a science contest for kids 6-8 grade?? I really want to win this!!
Oct 21, 2011. 1:43 PMkamid99 says:
Thank you!! I'll definitely use the instructions!
Oct 21, 2011. 11:06 AMkamid99 says:
thank you!!please send the pics!!!
Oct 18, 2011. 2:05 PMkamid99 says:
Yess!!! I mean obstacle avoiding. Sorry for any confusion. Thank you!!
Aug 21, 2011. 5:27 PMtheswordninja561 says:
does any one know if you can somehow attach something to this to make it r/c sorta kindish ?
Aug 21, 2011. 5:25 PMtheswordninja561 says:
man, if i get the chance to make this i'm going to customize the s@#$ out of it......
Aug 18, 2011. 11:49 AMMistwalker says:
I very much like this sort of simple design. I'm wondering, however, if there's an easy way to make this light seeking. Maybe if you had a pair of light sensors?
Jun 27, 2011. 3:51 AMredorchestra says:
it would be really cool if you could have the motors alternate so it walks in a jerky side to side motion.
cool robot, love the tripod
Mar 4, 2011. 6:50 AMGernerakos says:
This is realy good it look like very simple.try to make this
Mar 2, 2011. 8:07 PMwhisper199 says:
looks pretty good made me want to do a solar powered calculator or a piano
very original
Feb 25, 2011. 4:42 PMjonnis says:
I'm sorry for asking here, but what is the green mat called?
Feb 26, 2011. 12:41 PMxAxrules says:
craft mat, cutting mat, etc
Feb 21, 2011. 10:09 PMDrevMaster says:
Do not think I made a little robot is so simple.
Feb 21, 2011. 11:09 PMDrevMaster says:
:) It's because I'm from Russia, I know English bad and I use Google's translation. The design of the robot is very simple. Liked it.
Feb 20, 2011. 8:57 AMmaewert says:
martzsam,
Cool project, but I don't quite understand what is going on.
Do the batteries need to be charged to get the 'nominal' motion and the extra light on the cell adds the additional power to increase its speed?
Said another way, without the batteries does the robot move in the light but only at 1/2 speed?
Or is the extra light only hitting the light sensor and that's what's increasing the speed of the bot?  (This wouldn't make sense because the light sensor is supposed to turn off the device when it gets too light)
Did you have to do something to the light sensor since normally the light sensor turn off the power to the circuit when it is sensing light since this function is to turn on the 'load' when it gets dark?  Said another way does the robot stop moving in bright light?
Are the batteries wired in parallel or serial?  If serial then I wouldn't think that they were being charged at all since the circuit would be designed to charge a single cell and would not provide sufficient voltage to charge two cells.
It would be nice if the robot would continue to charge the battreries when switched off.  Have you cheked that there is no current going to the betteries when the switch is in the off position?  Without knowing the circuit design we really aren't sure what's going on in it, like it operation in the off position, how the light sensor works, or if the battery charging circuit has over charging protection.
Thanks for posting the project matrzan!  I really light the idea!
Best Wishes
Feb 20, 2011. 1:22 PMmasynmachien says:
Hi, great project!
Can you explain why the light sensor speeds up the motors? Do the motors simply replace each LED (and one motor explicitly does so, if I read it right, I guess the other one to)? One would expect the motors to slow down when the light hits the sensor. Or am I missing some alterations to the to the garden light's circuit?
A garden light' s circuit normally contains some kind of joule thief circuit to drive the LED(s) from a single 1.2 V battery, with an extra to have darkness switch it on.
Maybe the light sensor influences the balance between voltage and current? When dark: high voltage, low current needed for a LED, when light: low voltage, LED doesn't work, but higher current possible.
LEDs cut off below a certain voltage, no matter the current, while motors are strongly controlled by current. Of course motors are at the same time controlled by voltage, but I expect the garden light circuit to provide a rather low current (designed for LEDS), making this current the limiting factor.
Does this make sense?
Feb 17, 2011. 6:19 PMGhost Wolf says:
Can it turn on it's own?
Thank you for putting a video I would have been screaming for one
Feb 19, 2011. 3:12 PMJoshuaZimmerman says:
Thats quite cool! I'll have to try making one soon.
If someone was to make this using just their own parts, could they do this.
Make two separate little solar circuits, each with it's own solar panel and motor, and hook it onto the same frame. Thus making it a very simple light seeking robot?
Feb 18, 2011. 1:40 AMHarveyH44 says:
You could have given each motor it's own control board from garden lights, and made it light seeking. Both boards could have shared the batteries and solar panel.
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:martzsam
I am 15 years old. I have been interested in robots since I was very young. I got a Lego Mindstorms set and immediately began experimenting. Robots are a fun way to advance knowledge and help people i...
more »
