Step 4Solar panel mounts
Once your wires are all routed and zip tied, your batteries and panels held securely down, double check every thing and you are ready to go.
Performance:
This Solar Powered Trike does about 15-18 mph depending on the weight of the rider. The furthest I have gone is a little over 10 miles with small hills and little pedaling, and the battery meter still read full (green) at the end of the trips.
At ten miles, the voltage drops to around 36V, safely above the controller's cut-off voltage. If the batteries are kept from discharging too low the panels take about the same amount of time as the plug in charger, since both the plug in charger and the solar charge controller charge with constant wattage. With constant wattage charging, Power, (P), and Ohm's law again (P=V*I), the charging current goes down as the voltage goes up, as the batteries near their fully charged state.
What this means is if you keep the voltage from dropping too low, the panels provide adequate current to match the charging speed of the plug-in charger, but if it drops below a certain point the panels are slower at charging. This is easily avoided since my typical trip range is around 3 miles or less, semi daily at most, so low voltage not an issue, but on longer trips I bring the multi-meter.
Cost Breakdown:
The Trike cost a little over $910 to build
Schwinn Meridian Trike
$250.00 www.K-Mart.com
Q-cell Mono-crystalline Solar panels:
$330.00 www.Ebay.com....
Charge Controller:
$ 95.00 www.solarseller.com
Electric Hub Motor Kit
$260.00 www.goldenmotor.com- also sells regenerative braking motor speed controllers
Batteries
$ 60.00 Earl's industrial liquidation, Hawthorne, CA
High pressure tubes $ 15.00 Any bicycle store
Total $910.00
Other solar trikes / information
http://www.solartrike.com
http://www.therapyproducts.com/products_sunnybike.html
http://www.csulb.edu/~rtoossi/engr302i
http://www.kyosemi.co.jp/product/pro_ene_sun_e.html
http://www.nanosolar.com/
The last picture is a scan of a page straight out of Dr Reza Toossi's book,
Energy and the Environment, Sources, Technologies, and Impacts.
Book information / purchase
http://www.vervepublishers.com/
And the Q-Cell website offers no hint as to where to purchase their panels. Oh and one last thing, and ideas as to where to purchase the best batteries? Money is an issue.... Thanks.
The point is - there are always options and I would disagree with your assessment that this couldn't be reliable. As long as you can pedal, you can make 8 miles in a pinch.
Personally, I wouldn't want to carry around expensive PV panels and risk breaking them. I'd rather install them at my house and slow down my meter (which I realize requires some pricey equipment) and just charge when I need to, or have 2 or more battery packs so one or two are always ready to swap out. The PVs will get used whenever sun is available (and the bike is in the garage) making the PVs payback time shorter.
With regard to many of the other Negative Nellies saying this isn't healthy, green, etc. I would love to see what you've come up with. I put together an electric bike 4 years ago and it has paid for itself many times over financially (costs around $.01 electricity per 4 miles without pedaling) and environmentally (for both carbon offsets or jusy energy inputs for the manufacturing energy used + electricity to charge) vs. a 34mpg car which is what this replaced.
I find that I like to pedal with it to baby the batteries and extend my range. I coast downhill and pedal at the same cadence and power whether I'm on a flat or uphill and adjust the electric use accordingly. I still get lots of exercise but not so much that I'm all sweaty when I get to my destination.
I would prefer to see some constructive ideas instead of "that won't work".
"Those who say it cannot be done should not interrupt those who are doing it."
--Chinese proverb
I am not trying to find a way to do something - I have done something that works very well, thank you. I stated that it is reliable and have compared the payback time compared to a 34mpg car including maintenance and fuel. I have actually my own very self ridden for 4 years approximately 5+ miles a day 5 days a week to work.
I have had to only replace tires and brakes. Regarding battery usage. You are ignorant about lead acid batteries. Life expectancy is greatly enhanced by not discharging below 50% and immediately charging - SLA batteries will sulfate quickly if left discharged.
I'm not missing any point - you are are being intentionally obtuse. To me, "let's not pretend it is a reliable form of transportation" == "it won't work". My point is that it is a good, inexpensive, viable option for a non-trivial percentage of people and that percentage of people would increase as more large vehicles got off the road and small vehicles were more common.
I put my Chinese proverb in to tell you to quiet down because I am doing it - right now, with a wilderness energy 26" brushed electric hub kit, a Mongoose mountain bike, and an Extracycle kit. All off the shelf and readily available 4 years ago. I spent around $800 at the time and has paid for itself many times over. It has been a great option for me and as you said - perhaps not for others. But there are a non-trivial number of people for which it would be an excellent option, especially for $800-$1000.
