A rc car with two solar panels strapped up top for charging power. (Sorry no images) video coming soon. This is my first Instructable so be as honest as you can be
Step 1: Scavenge the parts
The first thing is to get the parts. You will need:
-Scavenged chargeable rc car (the bigger the better)
-two 12 volt solar panels (flexible is best)
-1-2 diodes (two if you recharge the controller battery)
-(optional) panel for controller that is close to its voltage
-(optional but recommended) old computer fan whatever size works
Tools:
-soldering iron
-solder
-wirestrippers
-duct tape
solar car says: May 16, 2012. 8:18 PM
im also going to build a car thats solar powerd. would it be hard?
epierce in reply to solar carMay 21, 2012. 6:51 PM
My solar powered electric trike actually has almost 1500 miles on it. The panels produce 15 watts at 24 volts. This will charge the batteries but will not run a 450watt motor. Hope that helps.
solar car says: May 16, 2012. 8:14 PM
im building a solar powerd car for a show at a elmentry school...any tips?
nice car by the way
marianhanna says: Oct 8, 2011. 11:48 AM
good
frdmrckr (author) says: Mar 21, 2011. 7:46 PM
Fans for Cooling, things got very hot sitting in the sun, was afraid of the battery pack getting damaged
noor_karzon says: Mar 21, 2011. 5:55 PM
Why the fan?! What is the purpose ?!
heavydeath says: Aug 23, 2008. 3:50 AM
how did u run the energy straight in to the car u didnt use rechargeble batterys
starwarsfan in reply to heavydeathFeb 7, 2009. 8:08 AM
he probably just hooked it up to the motor with no batteries
frdmrckr (author) in reply to starwarsfanJul 10, 2010. 6:46 AM
The batteries were originally rechargable. I just threw a diode in and ran the solar panels to the same terminals the battery pluged into. It did charge them decently. That way if i did run into shade it still ran.
Mr.NHRA in reply to frdmrckrJul 25, 2010. 7:42 AM
I guess i should have read this b4 i made my solar hummer. Its basically the same thing because neither of ours runs directly of solar.
frdmrckr (author) in reply to Mr.NHRAJul 25, 2010. 10:44 AM
well i also did run it without the batteries too. The batteries were a 9 volt rechargeable pack. The panel was 12 volts but the amperage was a little lower. it ran fine without them. Just the shade killed it...
handywomanparty says: May 13, 2009. 8:34 PM
the fan is for cooling down the engine but he or she should of not used it because it is a small car and im not sure if it would get heated that much but if im wrong fell fre to correct me
frdmrckr (author) in reply to handywomanpartyJul 10, 2010. 6:47 AM
I used the fan to cool down the whole system. Sitting in the sun it got very hot and i was afraid of causing damage due to heat. its not needed
2muchfreetime says: Jul 3, 2008. 8:59 AM
Great Idea! I'm going to try it with a frame rather than a whole car body. It might solve the speed issue. How much did your solar panels cost?
the tech head in reply to 2muchfreetimeJul 9, 2010. 5:06 PM
now solar panels are cheap
ReCreate in reply to 2muchfreetimeMay 15, 2009. 6:10 PM
They can cost from 60 to several hundred dollars
frdmrckr (author) in reply to 2muchfreetimeJul 29, 2008. 4:56 PM
Free. They were donated to me from a friend
ReCreate in reply to frdmrckrMay 15, 2009. 6:09 PM
Wow,A friend Gave you that?
PCvsMac in reply to frdmrckrAug 6, 2008. 10:05 AM
God bless your friend... I was going to do something like this but a bit more simple...
Gary1995 says: Feb 28, 2010. 7:06 PM
 i thought that r c care for a second was a ps3 with wheels
knight2067 says: Aug 22, 2008. 6:41 PM
Dangerous, but I might try with a r/c helicopter... Probably should keep the battery pack fully charged in case of cloud.
ReCreate in reply to knight2067May 15, 2009. 6:08 PM
An RC helicopter Would not be able to hold it up,at all
deathpod in reply to ReCreateJan 22, 2010. 1:58 PM
Radioshack sells small superlight silicone panels that put out .5v. I'm gonna try to afix an RC copter  with some to trickle charge the battery in flight.
Glockenator says: Dec 5, 2009. 7:18 PM
the tag on that cable makes no sense
stallionspirit8 says: Oct 15, 2009. 7:39 AM
incredible instructable!
i have a school project to make one similar to this, and i was wonderingwhere you could get similar, cheap solar panels.
Thank you!
Junkyardmaster14 says: Sep 5, 2009. 6:42 PM
what is the size of the solar panel?
santi says: Sep 5, 2008. 4:22 PM
where i buy the solar panel
ReCreate in reply to santiMay 15, 2009. 6:08 PM
You Can buy them somewhere for (If your really lucky) 60-300 bucks
thepaul1993 says: Sep 15, 2008. 10:58 PM
what is the fan for?
ReCreate in reply to thepaul1993May 15, 2009. 6:07 PM
Wasting Electricity,We don't want it to go faster than 0.00000001 MPH
gamefreek says: Mar 27, 2009. 9:20 AM
how fast dus it go. i bet is slow as hell
if you like R/C cars go tohttp://www.hpiracing.com/
juanvi says: Jan 15, 2009. 10:19 AM
could you add pics of the nection of the solar panels with the car and diode, please?
brightwhite says: Oct 7, 2008. 4:54 PM
FreshPineSent says: Aug 23, 2008. 5:28 PM
(removed by author or community request)
FreshPineSent in reply to FreshPineSentAug 23, 2008. 5:29 PM
/sarcasm
knarx says: Aug 22, 2008. 11:52 PM
Finally featured. I am glad to see this.
neardood says: Aug 22, 2008. 8:00 PM
sorry, I don't get the comment on the far right in the first picture. I'm definately no spelling bee, but please can you at least proof read you're work? No hard feelings as its you're first
neardood says: Aug 22, 2008. 7:59 PM
I get the controller, but not the car.
neardood says: Aug 22, 2008. 7:57 PM
is teh fan for charging?
Sandisk1duo says: Aug 22, 2008. 6:15 PM
Batteries don't like heat
Dantex says: May 23, 2008. 1:28 PM
Why don't you enter "Discover Green Science Fair for a Better Planet" challenge. If you enter you got my vote!
frdmrckr (author) in reply to DantexMay 26, 2008. 5:55 AM
i will right now then thanks
Patrik says: May 19, 2008. 3:19 PM
Nice! Any idea how much juice the car needs, versus how much the solar panels provide? How long do you need to charge, vs. how long does it take to discharge? Will this actually move, running on just the solar panel?
frdmrckr (author) in reply to PatrikMay 20, 2008. 9:44 AM
The battery on the car is 9.6 volts. The panels put of 12 volts each and there both in parallel. It takes maybe about 15 to charge and runs close to 20 minutes. Yes it runs with just the panels but it tends to be slow and if it hits any shade it stops and I have to put it back in the shade
frdmrckr (author) in reply to frdmrckrMay 21, 2008. 9:32 AM
i meant put it back in the sun
TheWelfareWarrior in reply to frdmrckrMay 20, 2008. 3:44 PM
I've thought about doing something like this... whats the rated wattage of the panels?
PCvsMac in reply to TheWelfareWarriorAug 6, 2008. 10:06 AM
Usually you can tell by how many strips there are. Usually 0.3V each strip
frdmrckr (author) in reply to TheWelfareWarriorMay 21, 2008. 9:31 AM
Sorry but I don't know and I forgot what wattage was.
TheWelfareWarrior says: May 19, 2008. 3:30 PM
what is the purpose of the fan? Don't solar panels work better if they are flat on top of the car?
frdmrckr (author) in reply to TheWelfareWarriorMay 20, 2008. 9:41 AM
I had a problem with over heating when sitting the sun for long periods of time but now it doesn't. As for the solar panels they just ended up like that. I didn't plan that.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
