3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solar RC car
Step 2Wire the panels to car
First is to pull the car apart. You need pull the body of the top of the car. Then find the positive and negative terminals of the pcb in the car. If there is a cover over the pcd drill holes to run wires through. Take the two 12 volt solar panels and solder wires on them (make sure you have enough to lay the solar panel next to the car with the cover of). Solder the diode on the positive terminal. Then run the wires through the holes and solder in them parallel to the diode and negative terminals. leave the cover of for the next step.
2 comments
Oct 8, 2011. 11:48 AMmarianhanna says:
good
Sep 5, 2008. 4:22 PMsanti says:
where i buy the solar panel
May 15, 2009. 6:08 PMReCreate says:
You Can buy them somewhere for (If your really lucky) 60-300 bucks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:frdmrckr
