Step 4Wire it UP!!!
iImage Information
Time to bust out the solder iron! I wired it according to the attached diagram. If you'd like to forego the solar recharging aspect of it, refer to the attached SPST diagram. Notice the wiring of the DPDT center-off switch is different than a normal DPDT switch. Also, I found wiring the adapter to the cord quite touchy. Take extra care to solder it as clean as possible, and not to use too much solder, as this will make it hard to screw the plastic sheath back over it...
i messed up and bought a SPST center off switch.
is there anyway i can still incorporate the solar panel?
=( I tried to make the psp charger that jacob s. made and it didnt work...
i wired everything to his diagram correctly..i tested the usb port with a usb cord that was stripped to the red and black wires and nothing zip nope 0 voltage...
im really disssapointed .. i even have the 4 rechargable energizer batteries...
I think im going to try ur solar power charger and see if that works...
Im just wondering if i have to have the 6 prong switch that goes with the solar chrager? cuz i only have the 3 prong.
Reply bak to me asap
Thanks for replying to me.. its been very helpful
In simpler words u want to be link the 2 prongs not soldered and solder it to the prongs parallel? Correct?
Oh yeah i first thought u meant bridge it meaning just connect the tabs with one wire so which i switched it to the bridged (on) side .... the whole thing malfunctioned and started emitting smoke and i was like wth did i do wrong...
So thank you ...
I might do the solar charger cuz idk i really like free power even tho its small
I've bought 2 4.5v solar panels that runs at 200mAH i think. and i got one for about $.30 + shippng($2) so yeah...idk i like free power that is portable too There bigger that the tin itself tho
=) thank you so much chuck
Sry i had a lot to say.. idk i love mini projects but this one just took very long time cause of failure..=(
I think im going to finish this project in the summer...mroe time and less stress with school cuz just 2 more weeks left
=) happy summErs
