Total Spend: US$ 0.75 that's right, 75 cents! everything else was recovered from old electronic junk
This solar powered ornament spins at up to 200 rpm in direct sunlight and was made in about 5hrs.
2 spinners in early morning sun. This instructable is for the rear one.
Parts:
1. Strip of circuit board
This was pulled out of an old stereo, and was used to mount a series of small buttons along the face, I would think that any low profile electronics would have something similar such as CD/DVD players
2. Inductor coil
I recovered this from an old 5.25" floppy drive. There were 6 on the circuit board. I think 3.5" drives may have something similar you could use. Failing that, buy a "Major Henry Coil" from Solarbotics.com
3. 2 x decent computer fans
When I say decent I mean ones that will have smooth bearings in them. Cheaper fans don't have bearings and are no use for this project.
4. Neodymium Magnet from old hard drive
Recovered from an old hard drive, this magnet is super powerful.
5. Solar powered Led keyring torch off e-bay
These are really quite cool. I bought a couple of these off e-bay for 75c each including delivery from China. I used the solar panel, a LED, a diode and part of the case.
6. 3904 and 3906 transistors
These are pretty common transistors and can be found in a lot of electronic circuits. Recover these from old circuit boards if you can, or if you have to buy them they are very cheap.
7. 3300-4700uF Electrolytic Capacitor
Very easy to find but if you can't, make up around 4000uF by putting smaller cap's in parallel. I ended up using 3 1000uF caps instead of the 4700uF pictured.
8. 1000uF Electrolytic Capacitor
Same as above
9. 1n914 or 1n4148 Switching Diode
Easy to find, they look like a little glass bead that's red inside and has a black band up one end. I found one inside the keyring
10. 2 x 100k Resistors (Brown, Black, Yellow, Gold markings)
I was lucky enough to be able to pull these off the circuit board above.
11. Sheet metal for a base.
Back panel from an old stereo in this case.
Remove these ads by
Signing UpStep 1Keyring Destruction
from e-bay for AU$1.00 each including free postage. That's about 75 cents US
each.
After about a week they arrived from China and I opened the packaging expecting
to have bought a couple of pieces of garbage. But was pleasantly surprised to
find a couple of quality items.
The LED's were quite a bit brighter than I ever expected and after pulling one
of the keyrings apart I found that it was a REAL solar cell. (I've picked up a
cheap solar powered calculator before that after pulling it apart, found that
the "solar cell" was just some painted plastic)
Desoldering was extremely easy as everything (even through hole components) was
soldered only to the surface. i used a hairdryer to soften the glue holding the
solar panel to the circuit board and was rewarded with..
3 bright white LEDS
1 germanium diode which I'll use in the circuit
1 2032 Lithium Ion 3.6v rechargable battery with handy tabs for resoldering to
something else
1 nice momentary microswitch
1 low light solar panel giving 4.5V and 10.0uA at 200 lux
a quick google search on the markings and model number ST-3722-9
revealed this information.
http://66.102.11.132/translate_c?hl=en&sl=zh-TW&u=http://www.ssetc.cn/product.asp&prev=/search%3Fq%3Dssetc%26hl%3Den%26safe%3Doff%26client%3Dfirefox-a%26rls%3Dorg.mozilla:en-GB:official%26hs%3DiHx%26num%3D50&rurl=translate.google.com.au&usg=ALkJrhj5bo101_6VxstDsH-SXp4VBsWfTg
10
comments
Add Comment
zozzles
says:
Add Comment
